Author Topic: 130c dc motor questions  (Read 2283 times)
Offline Carter05Topic starter
« on: August 26, 2008, 11:21:20 AM »
I have recently picked up some 130v dc motors and was wondering what I could use to drive them. Is there something I could make myself? like a voltage multiplier of some sort? They only draw .49 amps and I don't know the stall current. Any help would be appreciated! Thanks!
Offline ArcMan
  • Mmmm... Plasma
Re: 130c dc motor questions
« Reply #1 on: August 26, 2008, 11:51:52 AM »
What you need is a motor drive capable of driving a 130 VDC motor.  Typically, motors with higher DC voltages like this are used on industrial equipment or machine tools.  My mini-lathe at home has a 100 VDC motor.  In my personal experience, I have not seen any hobby robotics driven with that high of a voltage.  It's not very convenient because you would have to have about 11 12VDC batteries in series to get the 130VDC needed to drive that motor.  It's also quite dangerous for a hobbyist.  130 VDC can easily kill you.
Offline pomprocker
« Reply #2 on: August 26, 2008, 01:04:56 PM »
i have a 130vdc motor that i control with AC using a speed controller i found on a surplus site for $30.
input is 120vac, output is a smooth 130vdc. theres even a place to hook up a pot to control the speed.
« Reply #3 on: August 26, 2008, 01:13:04 PM »
Ya I know about the AC speed controllers but I want to use it on a robot since they were free. I actually do have lots of 12v lead acids I could put together to get 132vdc and run em but it would be really heavy! If I remember right voltage multipliers work but the current capacity goes down drastically, so I would be wasting a lot of energy. Hmm....Anymore ideas?
Offline ArcMan
  • Mmmm... Plasma
« Reply #4 on: August 27, 2008, 09:31:33 AM »
That is incorrect.  Wiring batteries in series adds their voltages together, but does not affect the current supplying capacity of the batteries.  The current supplying capacity of the series will be equal to the capacity of the smallest (lowest current supplying capacity) battery.
« Reply #5 on: August 27, 2008, 09:40:47 AM »
Sorry I meant using a voltage multiplier circuit, not the batteries themselves, like a transformer kind of.
Offline ArcMan
  • Mmmm... Plasma
« Reply #6 on: August 27, 2008, 10:38:02 AM »
Oh, right.  I actually read your post wrong.   :P
Last post April 04, 2007, 06:08:44 AM
by sotu
Last post April 20, 2008, 03:57:44 PM
Last post May 17, 2008, 06:28:34 PM
Last post February 13, 2009, 09:14:29 PM
by MaltiK
