Author Topic: Problem with BUTTON command in PBASIC  (Read 1813 times)
Offline deathwing61Topic starter
« on: September 03, 2008, 07:23:06 AM »
following is my code. when a whisker button is pressed it runs the segment 10-20 times i only need it once. any idea what's causing this?
' {$STAMP BS2}
' {$PBASIC 2.5}
' My first Robot
' I shall call him... Jean-Luc
' Go forward untill you feel something
TOP:                      'lable
  HIGH 0                  'left wheel forward
  LOW 1
  HIGH 2                  'right wheel forward
  LOW 3
  LeftButton VAR Byte
  LeftButton = 0
  RightButton VAR Byte
  RightButton = 0
  BUTTON 4, 1, 255, 0, LeftButton, 1, LeftWhisker
  BUTTON 5, 1, 255, 0, RightButton, 1, RightWhisker
GOTO TOP
LeftWhisker:               'If left whisker contacts do this
  LOW 0                   'left wheel reverse
  HIGH 1
  LOW 2                   'right wheel reverse
  HIGH 3
  PAUSE 500              'reverse .5 seconds
  LOW 0                   'left wheel stop
  LOW 1
  HIGH 3
  PAUSE 500               'back/turn right .5 seconds
  GOTO TOP 'go back to program
RightWhisker:             'If Right whisker contacts do this
  HIGH 1
  HIGH 3
  HIGH 1
  LOW 2                   'right wheel stop
  LOW 3
  PAUSE 500               'back/turn left .5 seconds
Re: Problem with BUTTON command in PBASIC
« Reply #1 on: September 04, 2008, 07:27:02 PM »
This is because of something called 'bouncing'. Basically, even though you push it once, in reality it bounces really really fast. The microcontroller counts all of the bounces.
To fix it, just add a small "do nothing" delay like .25ms after the button push in your code.
Last post May 24, 2007, 12:19:51 PM
by aaqilkhan
Last post May 15, 2007, 02:05:46 PM
by JonHylands
Last post January 26, 2008, 10:10:28 AM
Last post October 30, 2010, 07:19:15 PM
