Author Topic: Collapsable Tubing Frame  (Read 2357 times)
Offline ArcManTopic starter
  • Mmmm... Plasma
« on: September 03, 2008, 02:21:00 PM »
I need to make a collapsable tubing frame for an accessory to my yard robot.  It will basically form a box shape.  I will make a heavy duty fabric liner which will slide over the top tubes to hold leaves.  I want to be able to easily disassemble the box and store it in a small space when I'm done with it.  This is the best idea I could think of for a lightweight collapsable box that holds alot of leaves.  When it's full, I intend to pick it up off of the robot and dump the leaves into the pile.
My question is this:  I've seen those tubing structures that have the corner box fittings with X, Y and Z connections.  Does anyone know where I can get these?
Also, I would love to hear other ideas for a lightweight collapsable box.
Offline RobD
Re: Collapsable Tubing Frame
« Reply #1 on: September 03, 2008, 03:09:33 PM »
You might check out the ATM (amatuer telescope making) websites.  Some of the big portable Dobsonian scopes use a collapseable truss mount design.
Offline waymental
« Reply #2 on: September 03, 2008, 03:13:34 PM »
use pvc. I made a paintball gun stand that folded up and went in my case with my gun.
Offline pomprocker
« Reply #3 on: September 03, 2008, 03:24:47 PM »
how about buy a cheap tent, and re-engineer it?
Offline Iron Man
« Reply #4 on: September 04, 2008, 07:17:00 AM »
8020, with hinges and what not?
  • Mmmm... Plasma
« Reply #5 on: September 04, 2008, 08:22:22 AM »
I wasn't thinking of hinges, but that's a possibility.  I was thinking of solid corner connectors from which the frame rods could easily be installed and removed.
« Reply #6 on: September 06, 2008, 09:15:54 PM »
I've seen collapsible laundry bag thingies.
Also kinda sounds like a lawn chair, modified of course . . .
Offline Gertlex
  • Helpful? 23
« Reply #7 on: September 07, 2008, 10:43:57 PM »
The first idea that came to mind for me (and only one before I read the rest of the thread) is two rectangles of tubing, connected to each other in the middle of their long sides.
When open, they'd form a big X.  The fabric would go around this and prevent them from closing back up.  When Closed, they'd be almost parallel || (though really, it'd just be a very steep X)  A zipper on the fabric would be opened in order to let the boxes close.
Hopefully that's a helpful idea :)
I
Offline stan
« Reply #8 on: September 08, 2008, 12:42:53 AM »
baby play pens and strollers have fold up joints strong fabrics.....most are tube construction.
I have a brain tumor and whats your excuse?
  • Mmmm... Plasma
« Reply #9 on: September 08, 2008, 11:28:29 AM »
That's it.  It should work great.  Admin's lawn chair idea is good, too.  But this would be much bigger, which is what I was thinking about.
Thanks all.
Last post June 21, 2009, 03:21:50 PM
by ksquared
Last post December 07, 2009, 06:13:02 AM
by davidc
Last post June 30, 2010, 11:21:57 PM
by YAWN
Last post November 29, 2011, 10:30:30 PM
by Mastermime
