Author Topic: $50 robot Serial Port Programmer  (Read 1743 times)
Offline offyTopic starter
« on: September 05, 2008, 07:19:39 PM »
Can I use a different type of programmer like one that is usb or something in that nature so I don't need to use a serial port? If so how will I do that.
  • Helpful? 107
Re: $50 robot Serial Port Programmer
« Reply #1 on: September 05, 2008, 07:35:43 PM »
The AVR ISP Mk II uses a USB port on your PC
« Reply #2 on: September 05, 2008, 08:04:47 PM »
Ok thanks. Also I just hooked up my servos straight to the battery pack and they work for 1 second and stop. I have the Futaba S3004 Servo. The battery pack measures 6 volts but for some reason does not power the servo that needs 4.6 - 6 volts. Also I hooked them right up to the battery pack to test them if you are wondering.
  • Helpful? 107
« Reply #3 on: September 05, 2008, 10:08:14 PM »
Do you mean that you just connected the servo straight to the battery pack? If so - then it wont do anything anyway. Servos, unlike DC motors, require a pulse to make them work - not a steady voltage.
they work for 1 second and stop Using the photvore code or the centering a servo code?
« Reply #4 on: September 06, 2008, 07:08:05 AM »
Thank you so much. When I finish building the micro controller I will test it.
Last post January 18, 2009, 09:29:37 PM
by Miles
Last post August 18, 2008, 12:15:46 AM
by harrythepotter2007
Last post February 03, 2009, 05:06:36 AM
Last post April 12, 2009, 04:13:09 PM
by GearMotion
