Author Topic: Lithium Protection Circuit  (Read 1731 times)
Offline airman00Topic starter
« on: September 07, 2008, 05:58:46 AM »
I am planning to use Lithium batteries on one of my projects and was wondering if I really need a protection circuit. I mean if I were to only have it running for like 1.5 hours and the circuit is short circuit proof(dipped in plastic), would it still be necessary?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Lithium Protection Circuit
« Reply #1 on: September 07, 2008, 06:27:34 AM »
The LIPoly batteries will blow up if discharged too much or overcharged. The role of the protection circuit is to prevent such problems.
« Reply #2 on: September 07, 2008, 06:58:25 AM »
but if I know they will not be discharged too high and I have a smart charger , then I don't really need one?
« Reply #3 on: September 07, 2008, 09:47:47 AM »
Lithiums dont blow up if you discharge them too much. They will if you discharge them faster than their C rate, but if you get its volts down too low it'll die quietly without a big fireball or anything.
Offline bldavis
« Reply #4 on: September 08, 2008, 05:32:28 PM »
I run lipo's in most of my planes and a Heli, i don't think the problem comes from the discharge rate (unless higher than the C rating) but I would much rather be safe than sorry, lipos will puff if used incorrectly and that will result in a fire ball if charged too quickly or allowed to overheat; weather it be by charging or discharging, or simply leaving them in a place where they get to hot i.e. the car. it is not a fun experience to distroy such a pricey battery. But, back to the point i think that the safty that a protection circuit will provide far exceeds the time or money that you will save. I think that a protect circuit should be used. But then again i am the guy building a guided rocket, ROFL,  :o
- have a great day and be safe (for yourself and those around you devices) still ROFL  ;D
- Website under construction -
http://www.mysapce.com/davisbe98ta
check me out on face book!!!
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #5 on: September 09, 2008, 09:47:39 AM »
Back in topic...
Dallas Semi offers some very good Li - ion / Li Po protectors... It's all about an IC... and some external but they are worthless...
Now the bad thing is that HELL they don't offer samples for their protectors... DARN, I wanted some... That's unfair....
Anyways...
I think TI has some protectors as well... Go there and see what you can fetch... they offer samples as well...
Good hunting,
Lefteris
Cheers!
« Reply #6 on: September 15, 2008, 03:53:49 PM »
Lithium's need a protection circuit, no way around it.
Discharging too much would damage the batteries. Charging too fast would start a fire or at best overheating damage.
If you have cells in parallel, you could get uneven charging, resulting in self-discharging.
Check these:
http://www.dimensionengineering.com/CellShield.htm
http://www.dimensionengineering.com/VHVBEC.htm
Last post April 05, 2007, 03:33:55 PM
by dunk
Last post January 20, 2009, 01:05:44 AM
by cosminprund
Last post December 15, 2009, 12:58:35 PM
by GWER57
Last post January 10, 2013, 12:32:21 PM
by claus
