Author Topic: Tiny NiMH battery Pack using 1/3 AA Batteries  (Read 5195 times)
Offline airman00Topic starter
« on: September 07, 2008, 06:14:23 AM »
Can I rig up 6 of these batteries in series and recharge them using this smart charger ?
1/3 AA NiMH Battery - http://www.megabatteries.com/item_details2.asp?id=13865&cat_id=425&uid=1661
Smart Charger - http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1566
Re: Tiny NiMH battery Pack using 1/3 AA Batteries
« Reply #1 on: September 07, 2008, 09:55:50 AM »
You could but the battery life would slowly go down after each charge. The lowest amp rating the smart charger can charge at is 0.9 amps, and thats pushing the limit of how many amps you should charge a little 280mah battery. I would be more comfortable around .5 or .6 amps, but since those are only $1 each, it wont be too hard to replace when they die.
« Reply #2 on: September 07, 2008, 11:21:23 AM »
Thanks for the reply
I'm gonna look for a smart charger that can does .5 amps like you said
Offline ArcMan
  • Mmmm... Plasma
« Reply #3 on: September 07, 2008, 03:52:58 PM »
If you want to make up your own battery pack, I would buy the tabbed batteries.  You just solder the tabs together, solder on leads, and shrink wrap the pack.  If you try to solder on the end caps of a non-tabbed battery, you can easily damage it from the heat.
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #4 on: September 09, 2008, 10:02:36 AM »
http://www.tjdmodels.com/e-commerce/tjdmodels/product.jsf?productId=1802
I got this charger some days before...
Just PERFECT... You can charge everything... except Sealed Acid Batteries... but no big worry here...
You can customize charging current and you don't have to worry about hooking anything wrong...
Plus, you can hook it up to your car's battery and start charging...
Good hunting, again....
Best Regards, Lefteris
Cheers!
« Reply #5 on: September 09, 2008, 04:30:30 PM »
@TrikyNekro
The link you posted give me an error
can you post another link or any picture or model # please?
Offline TrickyNekro
« Reply #6 on: September 09, 2008, 05:31:51 PM »
Eeehhh.... you are not lucky today...
Anyways...
It's the ULTRAMAT 14 from Graupner...
It's working from 100V - 240V AC or as I said before with 12V battery DC as the one in your car...
Cheers!
