Author Topic: avr isp mkII died?  (Read 2706 times)
Offline swallTopic starter
avr isp mkII died?
« on: September 07, 2008, 04:10:56 PM »
Uh-oh.... I was furiously programming, (successfully for the past few weeks with the $50 robot platform) and all of a sudden my programmer went dark.  AVR studio echos "problem connecting to programmer".
reconnecting USB for programmer yields nuthin..... no lights, nuthin.....
Has anyone else had the same issue?  Opening up the programmer (carefully) shows no fuses, or resets....
Arrgh.... my nice robot only has half a brain now..... desperately wants to be re-programmed.....
I dread that I may have fried it.  It is possible that I hooked up the robot to the programmer out of sequence (robot power off, connect programmer, turn on robot, robot may have been 'on' when I last connected the programmer) could it be this sensitive?
Thanks.
Offline pomprocker
  • Helpful? 16
Re: avr isp mkII died?
« Reply #1 on: September 07, 2008, 05:46:28 PM »
battery fully charged?
shorts in wiring on the board?
typos anywhere?
platform set for your specific atmega?
« Reply #2 on: September 07, 2008, 06:04:18 PM »
yep,
maybe
nope,
yep......
while I wiggle the 2x3 connector off and on the board, who knows if there is a short.....
it was working perfectly fine... correct lights in the body of the programmer..... the "connection" light was working fine too.... then all lights went out after I reconnected my robot......
I would connect, program, disconnect, let my robot roll around on the ground, rinse, repeat.......
then *poof*....
Offline airman00
« Reply #3 on: September 07, 2008, 06:08:52 PM »
Is the USB port still good or did you fry it?
« Reply #4 on: September 07, 2008, 06:11:30 PM »
I plugged it into other USB ports on two other computers..... no lights.....
*sigh*.....
Offline pomprocker
  • Helpful? 16
« Reply #5 on: September 07, 2008, 09:45:56 PM »
go over the 2x3 header on your MCU with a DMM make sure its still good
« Reply #6 on: September 07, 2008, 09:50:13 PM »
good advice.... will do.... .tomorrow however...
Offline waymental
« Reply #7 on: September 07, 2008, 09:53:56 PM »
My lights didn't come on either then I noticed I forgot to plug in my 9v.  :D
