Author Topic: search microcontroller  (Read 1554 times)
Offline os2beTopic starter
« on: September 12, 2008, 01:55:47 AM »
hi
i'm a software engineer  and i would like to build a robot with 2 wheel who have 2 motor, one for each wheel, detection sensor, ranging sensor...
there are a lot of microcontroller on the market, so i would like help to choose the right one
some "must to have" i would like to have
usb port
cpu >80Mhz
linux
I/O for made easy to add sensor, motor....
to add motor, sensor what is the best way
what do you suggest me?
thanks
Offline Trumpkin
Re: search microcontroller
« Reply #1 on: September 12, 2008, 08:56:50 AM »
Try the Arduino http://www.arduino.cc/
Robots are awesome!
Offline dunk
« Reply #2 on: September 12, 2008, 01:34:29 PM »
hi Osbe,
a few questions about your list of requirements...
usb port
do you mean USB host post or just the ability to read data off the device via USB?
linux
do you mean you want to be able to program the device from the Linux environment or do you actually want the device to run Linux?
if you are looking for a device that has a USB host port an runs Linux then you probably need to adjust your search terms.
try searching for "embedded Linux processor" rather than "microcontroller".
a broad generalisation here:
most microcontrollers will not have sufficient resources to run a full OS like Linux. (although there are minimal RTOS available for microcontrollers.)
as a result most microcontrollers cannot have USB host ports as you need to run a full OS to manage the USB bus and run USB drivers, etc.
there are devices on the market that have an embedded processor on the same board as buffers to handle TTL I/O but they are rare.
a more common approach is to have an embedded processor to run your OS connected to a microcontroller to handle I/O.
there are a few of us on this forum taking this approach in one form or another. my interpretation documented here: http://mrdunk.googlepages.com/processor
Offline Commanderbob
  • Embeddedmicro.com
« Reply #3 on: September 13, 2008, 01:37:55 AM »
If you want to run linux I would go with the AVR32. I have used the UC3B core (non-linux, more like a micro) and I like them. Or you could buy a gumstix and a robostix. Worked well for me.
« Reply #4 on: September 16, 2008, 10:33:18 AM »
usb port
cpu >80Mhz
linux
Why above 80 and with Linux? Actually, why an operating system at all?
ehhh but Arduino only has 16MHz :P
For USB and motors, you should buy external hardware. A serial to USB adapter, and a motor driver of your choice.
Offline Trumpkin
« Reply #5 on: September 16, 2008, 12:59:15 PM »
I know, but I couldn't think of a reason why he/she would need 80mhz. I did a quick google search and couldn't find anything with 80mhz.
« Last Edit: September 16, 2008, 01:24:03 PM by Trumpkin »
Robots are awesome!
Last post December 19, 2006, 10:51:15 AM
by trigger
Last post December 29, 2007, 09:13:59 PM
Last post November 13, 2008, 10:00:20 AM
by Tsukubadaisei
Last post August 23, 2010, 01:42:36 PM
