Author Topic: motor driver???  (Read 2311 times)
Offline karmaxTopic starter
motor driver???
« on: September 24, 2008, 01:31:41 PM »
i made AUV(autonomous underwater vehicle) in which i used sbc, from sbc i send signals to pic microcontroller then l298 motordriver.but its nt as efficent. i want to replace pic and i am thinking abt direct serial motor driver. any other idea regarding this....
Offline izua
Re: motor driver???
« Reply #1 on: September 24, 2008, 05:44:28 PM »
This item from pololu might be what you need. There's also the double version (for quite cheap, compared to the cost of two units) and the IC alone.
Offline ArcMan
  • Mmmm... Plasma
Re: motor driver???
« Reply #2 on: September 24, 2008, 08:54:21 PM »
Or the Dimension Engineering drives also interface via serial.  Note that it is 5V serial, so if your SBC has an RS232 port you will have to level-shift it to 0-5V with a MAX232 or equivalent.
Re: motor driver???
« Reply #3 on: September 25, 2008, 08:18:53 AM »
i am looking for serial motor driver
  • Helpful? 111
Re: motor driver???
« Reply #4 on: September 25, 2008, 11:37:04 AM »
Do you mean like this: http://www.pololu.com/catalog/product/410
but being able to supply more current?
Re: motor driver???
« Reply #5 on: September 25, 2008, 11:53:20 AM »
i am looking for serial motor driver which can work for 24v,5A motor.
Offline ArcMan
  • Mmmm... Plasma
Re: motor driver???
« Reply #6 on: September 25, 2008, 02:12:38 PM »
That's the info I gave you.
I have one driving 2 24VDC motors via a serial link right now.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: motor driver???
« Reply #7 on: September 25, 2008, 05:48:02 PM »
Please don't double post.
http://www.societyofrobots.com/robotforum/index.php?topic=5351.msg41436#msg41436
If that isn't good, look at the Syren model.
« Last Edit: September 25, 2008, 05:50:00 PM by Ro-Bot-X »
