Author Topic: Joystick wiring diagram  (Read 2203 times)
Offline ang5tTopic starter
« on: September 27, 2008, 11:28:39 PM »
Hello. Ok now, I had a previous post about joystick wiring I had posted in the mechanics section, realizing soon after it should have been here. But I have everything working smoothly now. Here is what I did for those interested in using a joystick for control.
I/O ---------(220 ohm resistor)--------------------------------------
                                     (0.01 uF capacitor)               (Joystick pot)
                                           (ground)                            (ground)
If you have made or have experience with the $50 robot photoresistor, or using a resistor as a control method, just use some code like that and you should be fine. I can post what  I am using now if anyone wants, but it is in Pbasic, and I'm pretty sure cannot be used with $50 robot. Please correct me if I am wrong. Thanks.  ;)
So if the blue wire goes here, then that means...(bzzzt) oops....
Last post October 21, 2007, 11:34:06 PM
by mr_kim85
Last post March 30, 2008, 02:27:10 PM
Last post September 22, 2008, 09:32:21 AM
by ang5t
Last post May 28, 2009, 11:31:02 AM
