Author Topic: wires for $50 robot  (Read 1959 times)
Offline icoms8Topic starter
wires for $50 robot
« on: September 28, 2008, 01:34:11 PM »
the wires i got for the $50 robot are very stiff but the wires that came with the servors are like stirng were do i get these wires?
Offline offy
Re: wires for $50 robot
« Reply #1 on: September 28, 2008, 01:46:30 PM »
If you go to Home Depot, Ace, or Lowes they should have those wires. Just ask them for circuit board wires and that should be close to the ones the servo's have.
Offline gamefreak
  • Robo-Enthusiast
« Reply #2 on: September 28, 2008, 02:09:00 PM »
around 20 gauge is the general sized wires for that amount of current, but don't use wires that small for loads over an amp.
Offline Trumpkin
« Reply #3 on: September 28, 2008, 02:33:16 PM »
The kind of wire used with the servos is called stranded wire.
Robots are awesome!
Offline pomprocker
« Reply #4 on: September 28, 2008, 02:34:21 PM »
servo wire is 26 gauge I think. I smallest that radio shack sells is 22 gauge. you have to go to an electronics shop that specializes in component electronics, not consumer electronics like radio shack.
also, solid core will be stiff, where stranded core is flexible
« Last Edit: September 28, 2008, 02:35:36 PM by pomprocker »
  • Helpful? 107
« Reply #5 on: September 28, 2008, 05:09:41 PM »
You can also search eBay for 'servo wire'. I bought a 3m length of 3 core wire (red/black/white) which I can cut to the correct length.
« Reply #6 on: September 29, 2008, 05:50:21 PM »
ok,now what number of wire do i use for the $50 robot's senors,batterys etc
Offline pomprocker
« Reply #7 on: September 29, 2008, 06:22:00 PM »
Id use stranded core 24 gauge wire in red black and yellow for your sensors
« Reply #8 on: October 03, 2008, 09:07:39 PM »
where can i get stranded wire and for how much?
« Reply #9 on: October 03, 2008, 09:13:14 PM »
also what gauge should i use for the battery?
Offline szhang
« Reply #10 on: October 03, 2008, 10:41:37 PM »
Anything >20 gauge should be good enough for most hobby electronics works.  You really don't have to pick a specific one.  Stranded is good if you're soldering, solid core is a must for breadboarding.
Radioshack should have all the wires you need (but they are a bit expensive).  Still, a spool (~ 5 bucks) will last you a while.
Last post June 05, 2010, 01:13:56 PM
by Jak24
Last post June 30, 2010, 10:45:51 PM
by Hal_Emmerich
Last post August 13, 2010, 04:26:37 PM
by SmAsH
Last post October 02, 2010, 06:30:19 AM
