Author Topic: charge pump regulators vs linear regulators  (Read 1289 times)
Offline szhangTopic starter
« on: September 28, 2008, 07:39:27 PM »
Hello,
I'm using 3.3V dsPICs (and 3.3V bluetooth modules) on my current project, and normally I would just go with a cheap linear regulator.  However battery pack is 12V and the 8.7V voltage drop across the regulator means alot of lost energy (and heat), so I'm looking into switching regulators/charge pumps.
I am wondering if anyone used stepdown charge pump regulators, and how good are they compared to linear regulators.
Thanks.
Offline paulstreats
Re: charge pump regulators vs linear regulators
« Reply #1 on: September 29, 2008, 04:07:45 AM »
try these switching regulators http://www.trossenrobotics.com/store/p/5163-3-3V-1A-Switching-voltage-regulator.aspx Their pin system is similar to a normal linear regulator.
If you are looking at a large voltage drop like yours then i dont think you have much chance of using a linear regulator, Its true that the more energy is wasted by the regulator then the hotter it gets. Which means that it will automatically turn off when it reaches a certain temperature to stop itself from burning out. Switching regulators or buck/boost regulators dont have this problem.
Last post January 12, 2007, 12:45:37 PM
Last post December 20, 2007, 12:51:45 PM
by SeagullOne
Last post July 07, 2010, 01:02:43 PM
Last post March 22, 2012, 06:05:59 AM
