Author Topic: interrupts tutorial  (Read 5960 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
interrupts tutorial
« on: October 03, 2008, 07:17:40 PM »
hello
can some one give me a complete tutorial about using interrupts?(of course in C i don't know bit of assembly.so tutorial in CCS C would be great.)
what I'm trying to do is when in put value of a Analog signal change to specific level then carry out a specific task(for example when in put signal of analog pin 0 changes from 1v to 2v turn on  LED A and when input change from 2v to 3v trn on LED B).I use CCS C for programming. :)
thanks
I'm Me
Offline szhang
Re: interrupts tutorial
« Reply #1 on: October 04, 2008, 01:57:39 AM »
First, what device?
I never used CCS C, but most of the compilers come with rather detailed documentation about their supported functions.  Also, reading the datasheets is pretty much mandatory if you want to understand how things like interrupts work.
EDIT: I'll assume you're using the PIC12F675 like your last poast
In any case, you probably need the comparator interrupt, which means you'd need to provide a reference voltage on another pin.  Or you can use a timer interrupt and check every 10 ms or something for pin status changes.  It would probably be easier.
Here is a tutorial on interrupts, it also recommend reading the help file.
http://courses.ece.uiuc.edu/ece445/wiki/?n=Topics.PICCCSCInterrupts
EDIT2: Ewww, the tutorial seems to have a 20ms delay inside the ISR... that's very bad, don't do it!
« Last Edit: October 04, 2008, 02:09:17 AM by szhang »
« Reply #2 on: October 04, 2008, 04:34:29 AM »
First, what device?
thanks
I'm Me
Last post January 09, 2008, 01:43:31 PM
Last post April 06, 2008, 11:23:08 AM
by superchiku
Last post June 22, 2008, 12:38:12 PM
by coldkryten
Last post January 09, 2009, 11:47:06 AM
