Author Topic: Servo Issue?  (Read 1775 times)
Offline OrrinTopic starter
Servo Issue?
« on: October 06, 2008, 08:13:22 PM »
I have successfully built and uploaded my program to the 50$ robot microcontroller. I have verified the program, but it still doesn't work correctly. The servos only spin in one direction.
At first I thought that the photo resistors were damaged, so I replaced and re-soldered them. This did nothing to help. The only thing that happens when I put on power to the board and servos is a continuous rotation. There is no reversal in direction nor any response at all to light or dark.
Now I think it could be my servos. I had them modified by Servocity.com to rotate continuously, instead of doing it myself (I'm lazy  :P). They have a little switch on the outside that reverses direction. Could this have something to do with it? Is there a different pulse signal for this to work?
Thanks,
Orrin  ;D
EDIT: The servos also rotate quite slowly.
« Last Edit: October 06, 2008, 08:20:39 PM by Orrin »
Offline ArcMan
  • Mmmm... Plasma
Re: Servo Issue?
« Reply #1 on: October 06, 2008, 08:23:06 PM »
(I'm lazy  :P).
Perhaps, but you're going to have to do some good old-fashioned troubleshooting.  Look at the micro's code.  What makes the wheels go forward?  Is that input present?
Welcome to what is about 25% of the time spent on the robotics hobby (at least for me).  Why doesn't this thing do what I want it to?
Re: Servo Issue?
« Reply #2 on: October 10, 2008, 04:57:07 AM »
Check everything with a multimeter for anything that shouldn't be happening.
If you change the servo speeds in the software, do the servos change speed?
Re: Servo Issue?
« Reply #3 on: October 11, 2008, 09:24:06 PM »
I haven't had a chance yet, but the servos don't seem to change speed with the light change. I might end up just making one servo turn and the other one just stay still. It might be slower, but it will still work. I will experiment with different values and see what results.
Thanks for your responses!
Offline sdavis6736
Re: Servo Issue?
« Reply #4 on: November 08, 2008, 05:57:15 PM »
Do you have common ground to all components, motors and board?  If not, you will have many strange things happening including the servo spinning in one direction, no control.
« Last Edit: November 08, 2008, 06:22:00 PM by sdavis6736 »
Last post March 05, 2009, 07:29:47 PM
by Canabots
Last post September 18, 2011, 06:01:09 PM
Last post July 12, 2012, 06:43:09 PM
by Pogertt
Last post December 02, 2012, 02:53:04 PM
by Mastermime
