Author Topic: A battery-powered USB Hub?  (Read 8447 times)
Offline SeagullOneTopic starter
« on: October 08, 2008, 07:16:53 PM »
Hello again everyone. I'm getting ready to finish my custom-built robot, NINA. One technical issue, though. My laptop only has two USB ports and I would need at least five to run the peripherals. I've been looking into getting a USB-4 port hub or two, but found out since I'm using a laptop that might quickly drain power! I then looked into seeing if anyone had any "battery-powered" USB hubs out there, but the only product I came across was Cyberpower 4-port battery powered USB hub. That only runs on four AAA batteries, and I'm rather skeptical that can provide adequate power of my robot's circuitry.
Could I just buy a self-powered USB hub and instead of using an AC adapter, plug a battery into it (at the right voltage of course ;D). To me, it only seems a matter that at the right voltage, the self-powered USB port will just soak up the proper current and nothing will be damaged. But with only a novice in actual electronics experience, I thought I'd check with some of you experts first.
Cheers!
I think the chauffeur did it.
He did.
Re: A battery-powered USB Hub?
« Reply #1 on: October 10, 2008, 04:47:41 AM »
Thats only true if you are powering the external devices with USB. What devices are you using?
Without knowledge of what you are doing, here is a thought. USB has four wires, one of them being 5V power. Cut that wire, and attach it to a 5V regulator connected to a 6.5V+ battery. And make sure you keep grounds common!
Offline dunk
« Reply #2 on: October 10, 2008, 05:44:16 AM »
Could I just buy a self-powered USB hub and instead of using an AC adapter, plug a battery into it (at the right voltage of course Grin)
yes. this works fine.
« Reply #3 on: October 10, 2008, 07:00:48 AM »
USB ports only give 500mA maximum.
a regular NiMH battery pack will give you 2300 mAH .  Thats over 2 hours of continuous runtime assuming the device is drawing the full 500mA ( highly unlikely)
« Reply #4 on: October 10, 2008, 11:10:46 AM »
Thanks guys.
My laptop will be communicating with:
1) a Sabertooth 2x25 via packet sized serial (using a TTL to USB converter cable)
2) a Lynxmotion 32 Serial Servo controller (using a serial to USB cable)
3) a PIC microcontroller which will handle my robot's sensors (using a a TTL to serial and then a serial to USB...or just another TTL to USB)
4) Two cyber Snipa spotter webcams without the zoom lens (running a basic stereo vision setup in roborealm)
Thanks again, guys! I'll look into self-powered hubs and battery packs and see what'll work.  :D
Loren
He did.
« Reply #5 on: October 10, 2008, 11:13:15 AM »
for 1-3, the biggest power drain will be the LEDs (basically nothing)
the webcams however will probably draw ~200mA each (estimated based on my experience with other cams)
« Reply #6 on: October 10, 2008, 11:56:16 AM »
Okay, thanks Admin.
So, on estimate, the most power drain I can expect is about 400ma (give or take a few milliamps).
I'll see how they perform on just my laptop via a bus-powered or self-powered USB hub (one with either option. That way, if I need to use an external power supply, I don't have to buy a whole 'nother USB hub.)
Thanks for all the input, guys!
Loren
He did.
Last post August 27, 2009, 06:27:52 AM
by Canabots
Last post November 24, 2008, 05:53:02 PM
by AdvsNoob
Last post June 15, 2008, 03:58:00 AM
by emmannuel
Last post November 23, 2008, 05:59:33 PM
by airman00
