Author Topic: UART on Interupt  (Read 1612 times)
Offline airman00Topic starter
UART on Interupt
« on: October 11, 2008, 07:27:57 PM »
Hi ,
How can I have a UART reading be taken on an interrupt ?
Meaning an interrupt on the UART Rx pin will trigger a "uartGetByte" .
I am using the ATmega168 and AVRStudio
EDIT: Found the answer http://www.societyofrobots.com/robotforum/index.php?topic=4886.msg38261#msg38261
EDIT: I still don't know the answer to the question below:
Also , if my transmission on the UART was lets say three bytes : 1 2 3. So the first byte ( 1) would trigger the interrupt to do uartGetByte , but would the uartGetByte capture the "1" byte , or would it skip it and only be able to capture the "2" byte?
Thanks.
Eric
« Last Edit: October 11, 2008, 07:29:26 PM by airman00 »
Offline ArcMan
  • Mmmm... Plasma
Re: UART on Interupt
« Reply #1 on: October 11, 2008, 08:28:01 PM »
Not an Atmel guy, but it's certainly got to be the same as a PIC...
You'll get the first byte.  That's what the UART interrupt is for.  It means "I have just received a full byte of data over the serial port.  Come and get it.".  "BTW - come and get it before the next full byte arrives or it will be gone."
« Reply #2 on: October 11, 2008, 08:31:41 PM »
To uart.h , would I just add this  to enable an interrupt on Rx UART?
//Enable Transmitter and Receiver and Interrupt on receive complete
UCSRB=(1<<RXEN)|(1<<RXCIE);//|(1<<TXEN);
//enable global interrupts
     sei();
and then add this to be the ISR portion
ISR(USART_RXC_vect)
   // Code to be executed when the USART receives a byte here
« Last Edit: October 11, 2008, 08:33:24 PM by airman00 »
Last post December 06, 2010, 06:35:36 PM
Last post November 12, 2007, 10:01:12 PM
by SomeSaba
Last post July 06, 2009, 07:44:13 PM
by Webbot
Last post January 20, 2011, 06:36:31 PM
by Graynomad
