Author Topic: Flash Byte Address Error  (Read 3209 times)
Offline airman00Topic starter
« on: October 12, 2008, 10:01:23 AM »
When I program my ATmega8 I get this error
Programming FLASH ..      OK!
Reading FLASH ..      OK!
WARNING: FLASH byte address 0x0000 is 0x1F (should be 0x1B).. FAILED!
Leaving programming mode.. OK!
Anyone know what this means and what I can do to fix it?
Offline izua
Re: Flash Byte Address Error
« Reply #1 on: October 12, 2008, 11:55:59 AM »
Verification fails because of a number of reasons nothing was written at the respective address (verification checks each byte in the hex file agains each byte written to the chip). Try programming another chip and see if this repeats. If it does, there is be a hardware/programmer problem. If not, the first chip is fcuked.
« Reply #2 on: October 14, 2008, 03:11:41 AM »
I figure you probably did this already with no luck, but just in case . . . try a full recompile of the code. That often fixes a lot of the weird errors . . .
Last post June 21, 2008, 11:43:43 AM
Last post February 21, 2010, 11:32:32 PM
by popcornhobo
Last post July 30, 2010, 05:45:43 AM
by Webbot
Last post August 22, 2010, 09:34:04 AM
by amando96
