Author Topic: 16F877A interrupt help  (Read 6122 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: October 12, 2008, 10:37:03 AM »
I have little question :- how to give an interrupt through any input pin?
lets say i want to turn on a led connected to Pin A0 every time i press a push button(with pull up resistor connected) which is connected to pin A1?
i searched internet and found a code.in that code push button is connected Pin B0.i modified it to do what i want(turning on leds) except changing the pin which push button is connected(which is B0).
so what i want to know is how to connect push button to a pin other than B0 and execute relevent programme.?
and is it possible to connect more than one push buttons and do different task using more than one external interrupt?
i use CCS C 4.057thanks :)
here is my code
#include "D:\PIC C codes\16F877A\intrrupt 1\interrupt1.h"
int x=0;
#int_EXT
void button_isr()
delay_ms(20);
if(x==3)
x=0;
else
x++;
void main()
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   enable_interrupts(INT_EXT);
   enable_interrupts(GLOBAL);
   ext_int_edge( H_TO_L );
   // TODO: USER CODE!!
   do{
   if(x==0)
   output_high(PIN_A1);
   output_low(PIN_A2);
   output_low(PIN_A3);
   if(x==1)
   output_high(PIN_A2);
   output_low(PIN_A1);
   output_low(PIN_A3);
   if(x==2)
   output_high(PIN_A3);
   output_low(PIN_A2);
   output_low(PIN_A1);
   }while(1);
I'm Me
Offline izua
Re: 16F877A interrupt help
« Reply #1 on: October 12, 2008, 11:40:46 AM »
You can't. If that pin is not an interrupt pin, you can't make it generate an interrupt.
You can fake it however - use a timer to scan the button n times per second, and if it's on (or off, or just transitioned, you decide) you can write some code. And since the timer only triggers in an interrupt, the code will be executed in an interrupt. You can use this method to add "interrupts" to more pins, but it will add more processing overhead.
« Reply #2 on: October 12, 2008, 05:42:23 PM »
well ow to do this timer thing.i'm new to this and dont know how to use timers.any tutorial would be great
thanks
I'm Me
« Reply #3 on: October 14, 2008, 03:15:08 AM »
You'll find an example of interrupt code for the 16F877 in my sourcecode here:
http://www.societyofrobots.com/robot_sumo.shtml
« Reply #4 on: October 14, 2008, 03:20:26 AM »
thanks I'll check
I'm Me
Last post February 05, 2007, 05:22:58 AM
by Hal9000
Last post June 27, 2008, 07:59:44 PM
by JesseWelling
Last post October 19, 2008, 06:28:44 AM
by aruna1
Last post February 27, 2009, 12:51:42 PM
by ArcMan
