Author Topic: 16F877A ADC help  (Read 4492 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
16F877A ADC help
« on: October 14, 2008, 09:48:53 AM »
i wrote a little code to measure varience of a LDR connected to A0 and run a motor.but its not working.can some one point me the error.
i used 16F877A with 4MHz crystal,CCS C .
do i have to give ref voltages also
#include "D:\PIC C codes\16F877A\sensor+pwm\sensor+pwm.h"
int x=0,y=0;
void main()
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_INTERNAL);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,99,1);
   setup_ccp1(CCP_PWM);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   // TODO: USER CODE!!
   set_adc_channel(0);
   while(1)
   delay_ms(10);
   x=read_adc();
   y=(x*100)/255;
   output_high(PIN_B0);
   output_high(PIN_C1);
   set_pwm1_duty(y);
   if(x<=256)
   output_high(PIN_B1);
   else
   output_high(PIN_B2);
I'm Me
Re: 16F877A ADC help
« Reply #1 on: October 16, 2008, 12:29:19 AM »
How do you know its not working? Compiler error? Robot isn't working? Sensor works but motor doesn't? Did you measure the LDR with your multimeter? More info please! And tell us what you did to try and debug it, also.
« Reply #2 on: October 16, 2008, 02:13:35 AM »
according to the code motor speed should vary with LDR sensitivity.i.e more ligt less speed low light high speed.but motor is not running at all.sensors give correct values but it seems PIC does not take thoes inputs
I'm Me
« Reply #3 on: October 19, 2008, 05:02:55 AM »
What do you mean? How do you know this? Did you check your circuit with a multimeter or using UART?
« Reply #4 on: October 19, 2008, 05:39:49 AM »
ya i check it with multi meter,
update pic takes in put(i wrote a code to turn on and off three LEDs indicating binary nubers 0 to 7 minimum light = 7(111),maximum light =0(000).so binary value changes with intensity.code worked.but when i connect motor it does not work. :(
I'm Me
« Reply #5 on: October 19, 2008, 06:07:39 AM »
Follow these instructions to fix your motor circuit:
http://www.societyofrobots.com/robot_faq.shtml#circuit_debug
« Reply #6 on: October 19, 2008, 06:28:44 AM »
I'm Me
Last post February 05, 2007, 05:22:58 AM
by Hal9000
Last post May 11, 2007, 12:59:34 PM
by Eco19R
Last post October 14, 2008, 03:20:26 AM
by aruna1
Last post February 27, 2009, 12:51:42 PM
by ArcMan
