Author Topic: newbie questions regarding microcontrollers  (Read 1748 times)
Offline Lazer57Topic starter
« on: October 15, 2008, 06:13:27 PM »
#1: Axon vs BASIC Atom Pro 28 with Bot Board II; whats better about the Axon and whats better about AP28/BB2? (i realize this is the home of the Axon, but i'm hoping for some straight talk)
#2: What is the best microcontroller for robotics?
#3: Can brushless motors get controlled with either microcontroller (in Q#1)? If yes, does it require a brushless motor controller?
#4: Can C# be used to program microcontrollers? (I am new to programming as well, limited C++ and AS3.0 experience, but want to learn C#)
And any other advice you can throw my way would be great.
Re: newbie questions regarding microcontrollers
« Reply #1 on: October 15, 2008, 06:46:41 PM »
If you use the hobby-grade brushless ESCs, you can use servo outputs to run brushless.
« Reply #2 on: October 15, 2008, 07:41:18 PM »
how do i know if they are hobby grade? i have seen many brushless motor controllers and so far none have mentioned anything about being hobby-grade.
« Reply #3 on: October 16, 2008, 09:54:58 PM »
http://www.societyofrobots.com/robot_faq.shtml#best_microcontroller
Yeap, you need a motor driver to run any type of motor (servos have built in motor drivers).
Just a note, brushless motors and their controllers are rather expensive . . .
Yes, as long as you have a compiler that can convert from C# to machine code required by your microcontroller. I'd recommend learning C, though.
Last post November 10, 2009, 05:28:54 PM
by Hawaii00000
Last post February 17, 2010, 06:32:09 AM
Last post February 24, 2010, 08:02:08 AM
by you eat waffles
Last post June 08, 2010, 12:27:29 PM
by paulstreats
