Author Topic: Little Solder Hole Thing On PCB  (Read 1406 times)
Offline airman00Topic starter
« on: October 19, 2008, 12:47:23 PM »
If you look in my PCB I designed you'll see a little solder hole thing right above the FTDI chip .
What is that solder hole thing and what am I supposed to do when I get my PCB in the mail? Solder in that hole? Leave it be?
Offline kd5kfl
Re: Little Solder Hole Thing On PCB
« Reply #1 on: October 19, 2008, 12:58:30 PM »
Problaby a plated through hole. A way to carry a lead from one side of the board to the other side. So two leads dont cross.
« Reply #2 on: October 19, 2008, 01:22:01 PM »
I thought it was something like that
but do I have to fill in (solder it) the hole? or is it good the way it is?
« Reply #3 on: October 19, 2008, 01:24:10 PM »
It is plated through by the PCB manufacturer, no need to solder it.
« Reply #4 on: October 19, 2008, 01:26:12 PM »
Ok thank you
« Reply #5 on: October 23, 2008, 07:07:56 AM »
Its called a via.
Vias are bad for high power tracing, and for noise sensitive circuits. For your circuit it's no big deal.
You should go all surface mount for this board - I'm willing to bet it will allow you to halve the size.
Last post March 09, 2008, 06:59:59 AM
by ScorpIon
Last post November 13, 2009, 05:13:47 PM
by SmAsH
Last post August 23, 2012, 03:25:28 AM
Last post February 27, 2013, 10:27:15 AM
by SUTO the G
