Author Topic: Products I'm gonna offer soon  (Read 7833 times)
Offline airman00Topic starter
« on: October 19, 2008, 04:19:51 PM »
Hello all ,
A month ago I finished a robotics product of mine  ( its a secret for now) . I've been going through the manufacturing phase - you know the planning , getting parts , making calls, etc. The robotics product will come out in stores in 2-5 months time .
Anyways the reason I was making this post was because I could start manufacturing 50 dollar robot boards similar to this one : http://www.societyofrobots.com/robotforum/index.php?topic=5268.msg40956#msg40956. The layout would be very different , but it would be more or less the same features. This extra PCB would not add any significant cost to the manufacturing run of my product, in fact it might even lower costs since the robot board uses almost the same components as my product (save money in bulk orders).
It would be layed out similar to the Axon - like a miniature Axon ;)- based off the ATmega168 ,USB uart( bootloader also?) and sell for approximately the same cost as an Arduino ($35).
What do you guys think of this? Would you buy one? Any suggestions?Any comments?
P.S. The robotics product is really cool , but I don't want to release details just yet. Hint: It can be used to make giant robots . But no more hints than that.
Re: Products I'm gonna offer soon
« Reply #1 on: October 19, 2008, 04:23:10 PM »
Make it look as close as you can to the Axon, and dont make a 100% profit from it ;). And I will buy it  ;D
« Reply #2 on: October 19, 2008, 04:38:43 PM »
Would you want to buy it presoldered or just a solder-it-yourself kit?
Offline izua
« Reply #3 on: October 19, 2008, 05:24:54 PM »
homemade PCB or professionally manufactured?
who solders the ICs?
« Reply #4 on: October 19, 2008, 05:37:01 PM »
all professionally done, soldered by a company .
Like I said, I'll be forced to charge at least 35 dollars for it (because of all the costs for manufacturing and soldering) - is there enough demand for this?
I was 1/4 way through my schematic and then I realize - hey I'm basically making the Freeduino! So I took the Freeduino files and I'm just modifying them a bit and changing the layout.
« Reply #5 on: October 19, 2008, 06:50:33 PM »
hmmm I'm starting to think its not worth it:
Heres my reasons :
Arduino and Freeduino do basically the same things my board does
It will cost me more to make these boards then a company who makes Freeduinos
I won't make so much profit since I have to compete with the prices of the Arduino and stay below $40.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #6 on: October 19, 2008, 07:38:43 PM »
Now see, that is why I gave up doing it  :P.
There is no perfect board for everyone. Because aplications are different. However, if you can make the boards with 3 pin connectors, with jumpers to select the power to the digital 3 pin headers, mini USB connector with the chip soldered, that would be perfect for small robots. Users can use the Arduino software (or just plain C) and can practice soldering their own headers, sockets, LEDs, resistors, etc. I may be wrong, but none of the Arduino compatibles has 3 pin headers for all the pins, so you may have a piece of the market there.
You may consider to use DIP version of the microcontroller so the user can plug in ATmega8, ATmega168 or the new ATmega328P.
« Last Edit: October 19, 2008, 07:54:57 PM by Ro-Bot-X »
« Reply #7 on: October 19, 2008, 07:57:49 PM »
yea the only difference would be the 3 pin headers. I'd be selling 3 pin header Arduinos .
Offline Ro-Bot-X
  • Helpful? 25
« Reply #8 on: October 19, 2008, 08:13:46 PM »
And that is a bad thing?
« Reply #9 on: October 19, 2008, 08:15:30 PM »
no but then again , is it all worth it in the end - I have to factor in labor.
I expect maybe 100-300 sales a year at around 10-20 dollars profit . Not that much cash...  1000- 6000 dollars a year from that . Its significant I guess, but I have to think about all the labor and stuff.
« Reply #10 on: October 21, 2008, 12:21:32 AM »
The market really needs something as cheap as the Arduino, but pinouts like the Axon. Seriously, one pin isn't enough to connect a servo!
But the Arduino is mass manufactured, like a year or two ago they claimed 10k sales . . . meaning they can get ultra cheap manufacturing prices.
Manufacturers charge way too much to solder on headers, so you'll either have to do it yourself, hire a highschool student, or have the customer do it.
With the extra headers, I doubt you can ever match the Arduino price and have it still worth your time.
I recommend selling two different types:
pre-assembled
not assembled
And of course price the pre-assembled one higher.
Good luck!
Offline Ro-Bot-X
  • Helpful? 25
« Reply #11 on: October 21, 2008, 05:48:07 AM »
Admin is perfectly right. I just want to stress out something. Make sure the microcontroller is DIP version, not SMD. Because noobs may brick it, so they will just change the micro, not the whole board. Back in 2005 someone told me about a manufacturer in Chicago who had good prices and who could make the boards different colors soldermask and silk screen. Some of the colors were cheaper... Let me know if you want me to look him up for you.
As for the board layout, other than jumpers for power selection for the headers, I would like it to have separate headers for TTL serial, jumpers to conect it to the USB chip, headers for I2C interface with power and groud (4 pin header). If you toy with the ideea of the bootloader, try the AdaBoot bootloader, since they say it is universal and also works with Arduino programming environment. Maybe make it in the form of the modules we talked about building as a comunity project, so we actually can use it directly for that.
Offline javafiend
« Reply #12 on: October 21, 2008, 09:51:15 AM »
Since three pin headers seem to be in high demand, what about designing an Arduino/Freeduino 3-pin header shield?
Offline Asellith
  • Helpful? 9
« Reply #13 on: October 21, 2008, 11:53:01 AM »
I've been toying with the idea for some time of getting into hobby robotics sales but its a hard market to get into at first. I could see after establishing yourself in the market you might be able to produce something like this product after you have the capital to keep your cost low. What you really need is something that will fill a space in the market and be unique. Then you are not competing with others and just have to worry about making a little bit of profit off each unit. Then once your name is known and you have a supply chain setup as well as distributors (ie sparkfun or one of a thousand other hobby style electronic sources) then you can afford to take the chance on something that will strengthen your name but might not make a lot of money. The main problem is finding something that fits a nitch market that has not already been done. might want to try something the the Maxbotics EZ-1 sonar sensor. Making complex sensors easy to use and cheaper is always a good idea.
As far as headers are concerned I would see a problem if someone sold me a board with no headers on it. The problem I always have is them not including the headers in the package so I have to get some of my own.
Jonathan Bowen
CorSec Engineering
www.corseceng.com
« Reply #14 on: October 21, 2008, 06:21:02 PM »
people like it when its all in one package - nothing else needed
if people had a choice between a regular arduino and one with 3 pin headers - they'd pick the one with the 3 pin headers
Offline Ro-Bot-X
  • Helpful? 25
« Reply #15 on: October 21, 2008, 08:50:13 PM »
I think you should say robot builders instead of people... Arduino comunity has lots of people that don't build robots. They are using Arduino for lots of different stuff, using shields for interfacing. For some of them, a RoboShield would be a great addition, and some of them would buy a Roboduino board right away. There is a demand waiting to be filled. I would go ahead and build both a shield and a board. Heck, people who allready own a board will buy a shield and the others will buy directly the board, since it will be cheaper than Diecimila + RoboShield.
« Reply #16 on: October 22, 2008, 05:07:51 PM »
I think I'll offer a board and a shield for robotics(for people who already have an arduino)
what I was originally aiming at was a modified-for-robotics arduino. That if someone was faced with a choice between Roboduino and the regular Arduino they would pick the Roboduino.
« Reply #17 on: October 23, 2008, 06:20:39 AM »
Anybody want any other features besides the ones below ( features that arent very expensive to add on)
USB bootloader
male headers on all pins
six separate servo pins ( unregulated power)
low dropout regulator
female headers for regulated pwr,gnd,unregulated power
Status LED
reset button
ICSP programming pins
« Reply #18 on: October 23, 2008, 03:31:54 PM »
USB would be nice as long as it doesnt take up a huge amount of space on the board.
Maybe leave out ICSP pins to make it smaller? The AVRISP needs a usb port to plug into your computer anyways, so might as well stick to the USB bootloader.
« Reply #19 on: October 23, 2008, 03:35:09 PM »
I think i'll leave ICSP if bootloader gets accidentally deleted or something
Offline paulstreats
« Reply #20 on: October 23, 2008, 05:28:56 PM »
why not add some of the ports connected to a mosfet or transistor so the ports can turn devices on and off at will without risking damage to the controller. that way sharp rangefinders etc.. can be turned on and off by the microcontroller. (or for a better example if you have a line follower with 5 ir led's, the controller struggles to provide power to all led's on its own but through a mosfet or transistor it can reliably turn them on and off allowing advanced functionality such as background cancelling and modulation).
You could add an i2c dedicated bus etc...
The trouble is knowing where to stop I suppose... Making a simple board with too many features can eventually turn into something difficult to use, always remember that you know how it works because you made it but try and think from the end users point of view, you can easily overwhelm somebody by adding too many features even though you or I think that they would be a good advantage. The only way to make a really well functional board is to allow it to work in a basic way and then switch the extra bits on when the users are ready for it through well structured documentation. I'm trying to create a board for release myself along with a few different types of hardware bases etc... but it really is difficult to know and plan for what the market knows and expects.
(welcome to the commercial developing world, the more people and competition there is the faster the future gets developed!)
ps. Cant wait to see what youre secret is!
Offline Ro-Bot-X
  • Helpful? 25
« Reply #21 on: October 24, 2008, 10:09:58 PM »
Thought it was a typo?
And yes, please add to the list of features the I2C bus (with power and ground pins, and place for pull-up resistors, just in case one needs them). Use the vertical mount resistor (0.1" spacing) for the pull-ups.
So when will the secret be out on the market? Does it make french fries? Hmm... I should build a robot that makes fries... Just kidding!
« Reply #22 on: October 25, 2008, 07:40:42 PM »
I think I'm gonna stop by the I2C - i thinks its too much. Maybe in version 2 . ;)
The secret product isn't really so amazing but incredibly useful when making large robots with a lot of DoF
« Reply #23 on: October 25, 2008, 07:48:30 PM »
quick question
if I do unregulated pins for 6 servos then those pins arent regulated which may cause problems for people who want more sensors.
So how many pins should be dedicated for servos?  Minimum of 2 , maximum of 6.
Offline Ro-Bot-X
  • Helpful? 25
« Reply #24 on: October 25, 2008, 09:33:44 PM »
So for that group of 6 servo pins add an other 3 pin header where the user can use a jumper (like those on the PC motherboard) to select regulated or unregulated power. I got this ideea from the OOPic-R board, where there are 3 groups of 5 pins, each group with its own jumper to select the kind of power you want. Check out my old board here:
http://www.societyofrobots.com/robotforum/index.php?topic=2228.msg14977#msg14977
or zoom in and check out the left side of the board where the servo pins are:
« Last Edit: October 25, 2008, 09:49:05 PM by Ro-Bot-X »
Offline Ro-Bot-X
  • Helpful? 25
« Reply #25 on: October 25, 2008, 09:46:36 PM »
That is too bad, since I2C is good for micro to micro communication (keeps the UART free for other stuff), for newer sensors like compass, Sharp GP2D12 I2C version, etc. The nicest part is that you can stack up many devices on the bus and it works perfectly.
Never mind, I just figured that SCL and SDA are the last 2 analog pins, so if you install the 3 pin headers close to each other, I can have the I2C bus split in two 2 pin female connectors and plug them in an L shape, where 2 pins are power and ground and the other 2 pins are SCL and SDA. The only thing that is missing (pull-up resistors) I can add on one of the slaves. But if you think you can squeeze them on your board, that would be awesome.
Offline izaktj
« Reply #26 on: October 27, 2008, 05:13:44 PM »
Hey you could sell photo sensors, no one makes those.
« Reply #27 on: October 27, 2008, 06:44:17 PM »
photoresistors? lol everyone makes those
Offline izaktj
« Reply #28 on: October 28, 2008, 12:04:57 AM »
I mean the whole sensor, photoresistor + resistor + wires + pin + housing.
« Reply #29 on: October 29, 2008, 07:49:01 PM »
guess what guys I put on I2C option .
There is holes in place for optional resistors to be pullups for the I2C. So you can use Analog or I2C. Your choice. :)
Cost of the Roboduino will be between $40 and $50. Sounds fair?
Last post December 10, 2008, 03:19:46 PM
by jamort
Last post June 21, 2010, 03:09:39 AM
by TrickyNekro
Last post September 12, 2010, 04:51:27 PM
by airman00
Last post April 04, 2013, 05:36:56 AM
by steve.rob
