Author Topic: Timer Overflow Interrupt not working  (Read 1720 times)
Offline mbatemanTopic starter
« on: October 21, 2008, 05:32:54 PM »
I think I must be missing something obvious. I am trying to use timer5 on the Axon. The timer itself is acting as expected, but I can't seem to get the overflow interrupt to work.
To test, I just did a very simple case...
ISR(TIMER5_OVF_vect) {
rprintf("Overflow!!!\r\n");
I do have external overflows working just fine, so I know global interrupts are enabled. Is there somewhere that I need to enable the timer5 overflow interrupt?
Offline bens
Re: Timer Overflow Interrupt not working
« Reply #1 on: October 21, 2008, 05:47:08 PM »
I assume you'll need to use one of the timer 5 control registers (probably something like TIMSK5) to enable timer 5 overflow interrupts.  Take a look at the datasheet.
- Ben
« Reply #2 on: October 21, 2008, 06:38:13 PM »
Doh! I knew it was something simple. I poured over so many registers in the datasheet, but somehow missed that one.
Thanks!!!!
-- matt
Last post October 30, 2007, 10:15:21 AM
Last post February 26, 2008, 11:45:07 PM
by frank26080115
Last post June 27, 2008, 07:59:44 PM
by JesseWelling
Last post June 14, 2009, 07:41:19 PM
by Tazdevil
