Author Topic: Modify Existing EagleCAD board  (Read 4620 times)
Offline airman00Topic starter
« on: October 24, 2008, 09:41:50 AM »
OK so I have a board design (.brd)  - specifically the Freeduino
http://www.freeduino.org/files/pre-freeduino_nkc_thru-hole.zip
How can I replace the 1 pin headers with 3 pin headers without having to add the part into schematic and then trace the board again from scratch.
I want to keep the board traces that were done already and just add in a part.
If I need to be more specific:
What I have : a schematic and board file ( that is traced already)
What I want to do : Add in a part into the schematic/board without having to generate a new board and trace that new board
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Modify Existing EagleCAD board
« Reply #1 on: October 24, 2008, 09:55:20 PM »
I think you have to go to shematic file, delete just the 1 pin header row, add 3 pin headers, reconnect the microcontroller to the new 3 pin headers and of course power and ground. Then you go to the board, you will have all the other pieces in place, just the new 3 pin headers will be to a side. You drag them to the place you want them to be and retrace from the microcontroller to the headers. Everything else will be in it's place untouched. If you still have remenance traces from the prevoius 1 pin headers, just rip up the old trace and retrace it manually.
« Reply #2 on: October 25, 2008, 06:22:20 PM »
Ok this is really wierd
I try to add a wire to the existing board in Schematic mode and it doesnt connect. I click the wire/pin I want my new wire to connect to and the wire is placed right next to it - not touching it.
Can someone try to download the files and add in a wire , they'll know what I'm talking about.
I'm on the same layer (91 Nets) as everything else , it just doesn't work.
What can I do so that I am able to edit the schematic?
Offline Ro-Bot-X
  • Helpful? 25
« Reply #3 on: October 25, 2008, 07:26:05 PM »
The units are not set the same as the builder used when he designed that board. I had the same issues. You have to set the units and the grid to a very fine resolution, then move the part a little so the pins snap to the grid. Then the wire will connect.
« Reply #4 on: October 25, 2008, 07:33:17 PM »
how do I do that
EDIT:
You do   View > Grid > then click Finest
« Last Edit: October 25, 2008, 07:34:08 PM by airman00 »
« Reply #5 on: October 25, 2008, 07:55:53 PM »
I get an error when I try to modify the schematic :
Warning  : Board and Schematic Not Consistent !  No Forward / backannotation will be performed .
How can I get around it.
« Reply #6 on: October 27, 2008, 08:08:50 AM »
Modify the schematic or modify the board? I only see that error when trying to modify the board (not allowed).
Offline Trumpkin
« Reply #7 on: October 27, 2008, 08:52:42 AM »
I ALWAYS get that error, it's so annoying.
Robots are awesome!
« Reply #8 on: October 27, 2008, 09:49:13 AM »
when I try to edit the schematic and switch to board so that the board updates with the new components.
@Trumpkin - I feel your pain
Last post October 10, 2008, 05:17:51 AM
Last post December 23, 2009, 09:55:35 AM
by little-c
Last post June 08, 2011, 02:19:58 AM
Last post March 04, 2012, 11:47:40 AM
by airman00
