Author Topic: Assorted $50 robot questions [UNANSWERED QUESTIONS ON 1ST POST]  (Read 3259 times)
Offline izaktjTopic starter
« on: October 25, 2008, 10:40:33 PM »
Unanswered questions:
None ATM  ;)
Answered questions:
1- 28 Pin DIP socket, what is it's function? (Yes I searched before asking)
2- Is it the same if I connect the servos ground to the 9v battery ground or 5v(regulated) ground? (I'm using battery pack)
Thanks.
« Last Edit: October 26, 2008, 05:15:00 AM by izaktj »
Re: What is the $50 28 PIN DIP SOCKET for?
« Reply #1 on: October 25, 2008, 10:56:51 PM »
so when u kill your ATmega chip , you can pop it out and replace it with a new one
« Reply #2 on: October 25, 2008, 10:57:57 PM »
That's it?
So if I'm using a breadboard I don't need it right??
« Reply #3 on: October 25, 2008, 11:27:05 PM »
right
« Reply #4 on: October 26, 2008, 12:09:59 AM »
Re: Assorted $50 robot questions [UNANSWERED QUESTIONS ON 1ST POST]
« Reply #5 on: October 26, 2008, 03:58:17 AM »
Offline dunk
« Reply #6 on: October 26, 2008, 04:27:23 AM »
all grounds should be connected together everywhere.
if you are using more than one battery pack in a circuit you will need to connect all grounds together.
your servo ground should definitely be connected to the GND on your 9v battery AND your 5v(regulated) GND.
i don't know the details of your circuit but 9V will be too much for your servos.
you will need to power then from a 5-6V source. (again make sure all the GNDs are tied together.)
« Reply #7 on: October 26, 2008, 05:05:56 AM »
Woot thanks mate!  ;D
I'm using a 6V for the servos and 9V regulated to 5V for the micro and digital inputs.
Offline yankeefan238
« Reply #8 on: October 26, 2008, 02:39:36 PM »
If you are going to use a 9v battery and regulate it to 5v you are gonna waste lot of energy and your regulator is going to emit a lot of heat.
« Reply #9 on: October 26, 2008, 03:10:46 PM »
I'm following the $50 robot tutorial  ???
« Reply #10 on: October 26, 2008, 04:01:10 PM »
you can use the 9V but I'm just saying that using 6V is more efficient.  ;)
« Reply #11 on: October 26, 2008, 05:51:16 PM »
Oh I see, yeah I understand. Thanks mate.
Last post May 17, 2008, 06:28:34 PM
Last post September 15, 2008, 03:24:50 PM
Last post October 07, 2008, 11:01:32 PM
Last post February 17, 2010, 06:32:09 AM
