Author Topic: Serial port  (Read 1529 times)
Offline vishalsaxenaTopic starter
Serial port
« on: October 31, 2008, 10:06:50 PM »
Hey people I have assembled almost everything in my $50 robot nd learnt alot.....
thnx to Admin......  :D :D
But I think my Serial port is not working properly >:( >:(........ I shorted 2&3 pin of my
serial port and ran Hyper Terminal program and did what is needed but this test failed
so does it mean that my serial port is not working or somehow its deactivated???
Please help!! ??? ???
Thank You
Vishal Saxena
Offline BuddingContraptionist
Re: Serial port
« Reply #1 on: November 01, 2008, 08:38:37 AM »
did you set flow control to none?
Re: Serial port
« Reply #2 on: November 04, 2008, 12:13:06 AM »
Check over everything with a voltage meter to find anything unusual. You probably just made a soldering mistake.
Are you using a serial to USB adapter?
Offline Half Shell
Re: Serial port
« Reply #3 on: November 04, 2008, 08:26:39 AM »
Also, hyperterminal can be a bit.... touchy at times.
I highly recommend for you to use Putty! It can do serial communication as well as telnet and SSH.
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
It's also free and can run in RAM if you really want.
Last post October 07, 2010, 01:40:24 PM
by offencerobotics
Last post November 13, 2010, 12:54:46 PM
by VegaObscura
Last post July 15, 2011, 12:38:58 PM
by adanvasco
Last post September 20, 2011, 05:22:34 AM
by joe61
