Author Topic: what does an SRV-1 blackfin camera do  (Read 5917 times)
Offline TyLEr71Topic starter
« on: November 03, 2008, 06:04:24 PM »
what does an SRV-1 blackfin camera do.?? can you just mount it to your robot or do you need to program it and do all that others stuff to it. what do you need for this part to work on your robot.
Re: what does an SRV-1 blackfin camera do
« Reply #1 on: November 03, 2008, 07:08:51 PM »
can you use a laptop to see from your blackfin camera from your robot ???
« Reply #2 on: November 03, 2008, 10:57:08 PM »
Have you read the Blackfin documentation yet? It should explain it all.
The Blackfin is a camera that does all the image processing for you. You use a microcontroller to 'ask it questions' about what it sees, and it will send your microcontroller the processed answer.
Offline pomprocker
« Reply #3 on: November 03, 2008, 11:57:11 PM »
The blackfin is actually a microprocessor with a built in digital signal processor.
http://en.wikipedia.org/wiki/Blackfin
this setup by surveyor corp. uses the microprocessor hence the name blackfin camera
« Reply #4 on: November 04, 2008, 03:22:46 PM »
so you need a microcontroller so the blackfin will work
Offline pomprocker
« Reply #5 on: November 04, 2008, 04:12:51 PM »
Yeah you typically hook it up via UART. Its probably best to have a microprocessor with multiple UART and something in the 16-20mhz range with some good amount of onboard flash memory.
« Reply #6 on: November 04, 2008, 04:35:28 PM »
what would be the cheapest microprocessor i can get so the blackfin works...do you know any websites i can go to, to learn how to do this. I'm new at this and i need a lot of help.
« Last Edit: November 04, 2008, 04:39:38 PM by TyLEr71 »
Offline pomprocker
« Reply #7 on: November 04, 2008, 04:55:44 PM »
Datasheets are your friend.
Read the datasheet of the blackfin camera, and read datasheets of any microprocessors, and see which one is cheapest and can handle the requirements of the blackfin camera.
« Reply #8 on: November 04, 2008, 05:59:37 PM »
is this the data sheet
# 500MHz Analog Devices Blackfin BF537 Processor (1000 integer MIPS)
# 32MB SDRAM, 4MB SPI Flash
# JTAG (tested with section5 ICEbear USB-JTAG)
# SPI Flash and UART boot mode select
# External I/O Header (32-pin - 16 x 2 x 0.1")
    * 3.3V Input - 145mA total draw at 500MHz, including camera
    * Board dimensions - 50 mm x 60 mm (2.0" x 2.6"), 36g (1.25 oz) including camera module
    * 2 UARTS - tested at up to 2.5Mbps with CTS/RTS flow control
    * 4 Timers (2 share pins with UART1)
    * SPI - 2 slave select, 1 master select
    * I2C
    * 16 GPIO
    * "S-32 expansion bus" header will support stacking of expansion boards
    * RoHS compliant
would an Axon work ???
« Last Edit: November 04, 2008, 06:07:30 PM by TyLEr71 »
Offline pomprocker
« Reply #9 on: November 04, 2008, 06:59:18 PM »
but of course...
you need to learn to search the site and the forum...
http://www.societyofrobots.com/robot_tutorial_index.shtml
http://www.societyofrobots.com/electronics_blackfin_camera.shtml
There is even a discount on the blackfin camera available in some cases:
http://www.societyofrobots.com/robotforum/index.php?topic=4732.0
« Reply #10 on: November 04, 2008, 07:29:54 PM »
so it will work
« Reply #11 on: November 04, 2008, 09:00:29 PM »
so it will work
yes an axon would work
« Reply #12 on: November 05, 2008, 01:47:03 PM »
THANK YOU ;D .do you know how to put those two together
Offline pomprocker
« Reply #13 on: November 05, 2008, 04:10:57 PM »
-_-
I gave you a link above..you obviously did not search the forum or read my post.
« Reply #14 on: November 05, 2008, 06:33:03 PM »
Ooo didn't even see that my fault.
Last post August 13, 2009, 02:44:26 PM
by sonictj
Last post November 28, 2009, 11:46:47 AM
by hgordon
Last post November 30, 2009, 10:14:11 AM
by hgordon
Last post June 12, 2010, 06:51:05 PM
by javila
