Author Topic: Question about Atmega 8 IC chip on $50 robot  (Read 2403 times)
Offline ArmouralisTopic starter
« on: November 07, 2008, 04:23:53 PM »
hey guys,
i have a question about  which atmega8 IC chip to get because there are 5 different ones.  I am using furturlec.com and this is the link to the atmega microcontrollers:
http://www.futurlec.com/ICAtmel.shtml
which IC is the one that is used in the $50 robot?
please is possible give me the part number.
is it:
ATMEGA8-16PC
ATMEGA8L-8PI
ATMEGA8L-8PU
ATMEGA88-20PU
ATMEGA88V-10PI
edit:
Or should I get the Atmega16?
ATMEGA168V-10PI
its only like a few more dollars, and I want to upgrade the controler.
THANK YOU in advance :)
also i would like to reuse the chip that i get for the $50 for a little more advanced programming.
What i am asking is the chip that you are suggesting can be used for more advanced programming?
Would the ATMEGA168V-10PI serve the purpose?
Is it diffrent than using the ATMEGA8 chip?  Cuz they both have 28 pins
« Last Edit: November 07, 2008, 08:19:52 PM by Armouralis »
Re: Question about Atmega 8 IC chip on $50 robot
« Reply #1 on: November 09, 2008, 01:25:19 AM »
The part number is in the $50 Robot tutorial.
Also, if you open up the datasheets for each, you can tell the difference between each of those chips. (I could just tell you, but its a skill you need to learn as a budding robot builder :P)
Last post May 05, 2007, 01:28:26 PM
Last post March 19, 2008, 08:28:03 PM
by goatfish
Last post November 29, 2009, 10:50:46 PM
by ksquared
Last post September 05, 2011, 09:06:45 AM
by billhowl
