Author Topic: $50 Microcontroller to PC (6pin ISP)  (Read 1214 times)
Offline MaltiKTopic starter
« on: November 15, 2008, 07:20:11 AM »
I made a PCB for the atmega8-based MCU, and i realized all of the ICSP programmers use 10pins, so will the following work:
http://www.sparkfun.com/commerce/product_info.php?products_id=13
with
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380066688847#ebayphotohosting
« Last Edit: November 15, 2008, 07:21:55 AM by MaltiK »
Warranty
Offline sonictj
  • Helpful? 11
Re: $50 Microcontroller to PC (6pin ISP)
« Reply #1 on: November 16, 2008, 01:32:50 PM »
I have  a better solution, this is a usb avr isp programmer that only requires minimum soldering and has both the 6 and 10 pin cables.
http://www.adafruit.com/index.php?main_page=product_info&products_id=46
This will cost just about the same, and will be a simpler solution.  This programmer is avr studio compatible compared to the other programmer which I believe you would have to use with pony prog , which sounds like a hassle to use from reading the tutorial.
« Reply #2 on: November 16, 2008, 03:43:05 PM »
Ight I bought that, it does look rather convienent, thanks for the suggestion mate! Cheers!
Warranty
Last post February 02, 2007, 07:47:27 AM
Last post May 27, 2009, 03:55:55 PM
by jakx12
Last post March 28, 2007, 06:38:04 AM
by snow
Last post May 18, 2007, 11:54:11 PM
by Ro-Bot-X
