Author Topic: Robotic Dex hand Project  (Read 1929 times)
Offline divitTopic starter
« on: November 15, 2008, 12:29:14 PM »
I am making a dex hand which works on an adc and AT98S52.
I dont knw how to program a IC i have the circuit diagram i just need help if some 1 could giv me the coding for it. There are 16 sensors (i am using 5k ohm pots as sensors) .The sensors are given to the adc the adc will generate a digital value and give it to micro controller.The micro controller will then generate a pwm signal .The pwm signal is then given to the servo motors. I basically need a program which will enable each servo motor to move according to the adc value received.Therefore each each pot will drive a single servo motor.
Re: Robotic Dex hand Project
« Reply #1 on: November 27, 2008, 05:56:42 AM »
Interesting ADC chip, never seen that before . . . Normally I'd just say get my Axon since it's all done for you (and has 16 ADC), but you already have a circuit . . .
Also, there is no such thing as a AT98S52 . . . there is a AT89S52 however.
Have you looked at the code examples on this page?
http://www.atmel.com/dyn/products/product_card.asp?family_id=604&family_name=8051+Architecture&part_id=1918
Google has a bunch of source code on it, too.
Last post January 11, 2008, 10:28:50 AM
by Half Shell
Last post September 01, 2008, 04:13:16 PM
Last post August 24, 2009, 03:21:29 PM
by SmAsH
Last post December 01, 2010, 09:15:38 PM
