Author Topic: Hall Effect Tachometer  (Read 5263 times)
Offline CommanderbobTopic starter
  • Embeddedmicro.com
« on: November 18, 2008, 11:16:54 PM »
I am trying to make a tachometer with an AVR, a magnet, and a hall effect sensor. The hall effect sensor I have is this one. When there is no magnetic field it outputs around 2V that goes up or down if there is a positive or negative field applied.
Originally I though of using an opamp and the AVR ADC to check when the magnet went by.  The problem with this is I will be polling the hall effect sensor. Do you think it would be better to use a comparator and a pin change interrupt? If I used a comparator then I would have to use two and a OR gate to detect both + and - fields so I don't have to worry about which way I install the magnet. The magnet will not pass the sensor more then 450 times per second (~27,000 RPM), usually under 250.
Is it better to use one opamp and the AVR ADC, comparators and a OR gate, or something I have not mentioned?
Thanks,
Justin
« Last Edit: November 18, 2008, 11:18:30 PM by Commanderbob »
Offline hudbrog
Re: Hall Effect Tachometer
« Reply #1 on: November 19, 2008, 01:15:47 AM »
Imho AVR internal comporator is the way to go
  • Embeddedmicro.com
« Reply #2 on: November 19, 2008, 09:12:42 AM »
Can you set the voltage to compare it with to anything you want? I read that it uses the same reference as the BOD. Does that mean you can only use the voltages the BOD can be set to?
Offline omkar
« Reply #3 on: January 23, 2012, 05:42:13 PM »
A bit late to reply to this post but to anyone who finds it on google search ... here is the link to something I did and worked:
http://www.societyofrobots.com/robotforum/index.php?topic=14973.0
There are links to the Hall effect sensor I used and the arduino program related to it.
Hope it helps.
Last post January 02, 2011, 11:59:44 AM
Last post February 24, 2011, 12:21:41 PM
Last post January 27, 2012, 08:22:20 AM
by handyspacko
Last post April 24, 2012, 08:33:52 AM
