Author Topic: motors  (Read 1543 times)
Offline BuddingContraptionistTopic starter
motors
« on: November 20, 2008, 06:36:51 PM »
i think i want to make a wheeled contraption... where can i buy good robot motors?  I found this motor at sparkfun, which nicely matches this gearbox.  But that's the only motor and the only gearbox they sell.  Where is a good place for motors?  (and on a semi-related where-do-i-find-this-stuff note, anyone know where i can find one of these JST connectors for the sharp IR range finder? i got a rangefinder but forgot to get that cable and i dont want to order just one thing all the way from canada)
Offline Trumpkin
Re: motors
« Reply #1 on: November 20, 2008, 07:35:31 PM »
Robots are awesome!
  • Helpful? 107
Re: motors
« Reply #2 on: November 20, 2008, 08:52:45 PM »
See other forum posts re connecting directly to the sensor without using a connector
Re: motors
« Reply #3 on: November 23, 2008, 07:11:51 PM »
is it bad for a motor to run it at a lower voltage than it's rated at?  like if i get one that's 12v, but use a 9v battery to run it?
Offline paulstreats
  • Helpful? 20
Re: motors
« Reply #4 on: November 24, 2008, 06:15:54 AM »
solarbotics sell lots of different motors, many with gearheads already attached
Offline ArcMan
  • Mmmm... Plasma
Re: motors
« Reply #5 on: November 24, 2008, 10:19:32 AM »
No problem for a DC motor.  Reducing and increasing the DC voltage is exactly how speed control is attained.  So running a 12V motor at 9V just means that it will run slower with less torque.
Given that, let me say that running a motor with a 9V battery will drain that battery very quickly unless that motor is really small.
Re: motors
« Reply #6 on: November 28, 2008, 01:01:12 AM »
Running a motor at a lower voltage won't break anything, but as ArcMan said, it will have lower torque/speed.
A motor is most efficient at the rated voltage - meaning a higher torque/joule ratio. So less wasted battery energy, basically.
But the proper way to control motor speed is through PWM, which is like turning the motor on/off really fast so that it reaches some medium speed.
Last post November 05, 2009, 04:28:17 PM
by Webbot
Last post March 07, 2010, 03:55:21 PM
by waltr
Last post May 18, 2010, 09:42:45 PM
by antom
Last post December 02, 2010, 12:14:40 AM
by arnoldino
