Don't ad-block us - support your favorite websites. We have safe, unobstrusive, robotics related ads that you actually want to see - see here for more.
Maybe you want something like this: http://www.dimensionengineering.com/Sabertooth2X25.htm, it is expensive, but if you make one yourself it might cost just as much to get it not to melt.
I guess that most of us tend to think positive. As a result we under-engineer our own designs. So the problems with MOSFETs or diodes is not a problem with their construction - we've just specified a 'kid' to do a 'man's job - to keep costs down. The result is that they've blown.Some folk end up deciding that it actually ends up cheaper buying a pre-built one.Of course you can build your own h-bridge if you want. But beware of any 'peak' requirements - so 'over spec' your components if in doubt.
Also, the two top MOSFETs should be PNP, and the two bottom ones NPN.
Started by Admin Electronics
Started by vsching Electronics
Started by bilalbajwa Electronics
Started by Martin1512 Electronics
