Author Topic: Silk Screen not showing up in Eagle3D  (Read 2222 times)
Offline airman00Topic starter
« on: November 23, 2008, 08:50:37 AM »
For some reason the silk screen isn't coming up when I do a 3D cad of the Roboduino .Can anyone help me out with this one? Is there some option to set or something?
I get only this
Offline MaltiK
Re: Silk Screen not showing up in Eagle3D
« Reply #1 on: November 23, 2008, 05:39:03 PM »
Did you try going to
 View->Display/Hide Layers->Highlight all of the layers with the "t" in front of it->Press Ok
Warranty
« Reply #2 on: November 23, 2008, 08:56:05 PM »
There is a bug in Eagle3D where the silk screen doesn't show correctly, meaning its shifted from where it actually is.
Also, I noticed you used the smaller USB adapter. Since you have a budget board, I recommend using the larger USB connector and cable - you can reduce your cost by like $2/board. I still debate whether I should have done that for my Axon . . . lower price or smaller/lighter board . . . a tough decision.
« Reply #3 on: November 23, 2008, 09:02:44 PM »
For something like the Axon an extra $2 for a smaller connector would be worth it to me.
« Reply #4 on: November 23, 2008, 09:37:53 PM »
How can I fix this?
Yea the newer design uses the big USB connector . The first batch of Roboduinos use the big connectors. Definitely cheaper to go with big than miniUSB
« Reply #5 on: November 23, 2008, 09:57:39 PM »
How can I fix this?
no idea . . . if it's fine on the prototypes you make, that should be good enough . . .
« Reply #6 on: November 23, 2008, 10:24:46 PM »
How can I fix this?
its fine on the prototypes , just I want a nice 3D cad of it
Did you have any trouble with silkscreens when you made your 3D http://www.societyofrobots.com/axon/images/axon3D.jpg ?
« Reply #7 on: November 23, 2008, 10:37:35 PM »
yeap I had problems in two spots. look at the very bottom left of that image, where it has the Axon picture with the neuron. The line drawn from the A to the neuron is messed up in Eagle3D, but fine on the actual board.
The other problem was the societyofrobots.com url under the capacitor - Eagle3D wouldn't place it properly and resizes it too.
Eagle 3D also messed up the capacitor size but I was too lazy to figure out why and tweak it.
Last post February 28, 2007, 12:13:42 PM
by jsmoker
Last post January 02, 2010, 04:34:29 AM
by Joker94
Last post April 06, 2010, 09:10:30 PM
Last post July 17, 2010, 08:52:02 AM
by Gertlex
