Author Topic: Looking for a very cheap 3D aluminum machining sevice online.  (Read 2068 times)
Offline CubebotTopic starter
« on: November 25, 2008, 01:58:41 PM »
It should be under 100 dollars to machine a small, cheap aluminum box with some holes in it without welding.
Re: Looking for a very cheap 3D aluminum machining sevice online.
« Reply #1 on: November 25, 2008, 02:01:09 PM »
Think the Miabot pro chassis, this is linked with my earlier post about a small robot. The reason I must keep it cheap is that I am only 14 and need the entire package cheaper than 400 dollars.
Offline ArcMan
  • Mmmm... Plasma
« Reply #2 on: November 25, 2008, 02:26:38 PM »
What are you looking for exactly?  (dimensions, thickness, etc.)
« Reply #3 on: November 25, 2008, 02:38:52 PM »
It would be a 3x3x3" hollow cube with a screw-on top, it would have to fit two small servo motors, the Axon micro controller and two small holes in the front for stereoscopic infrared. The walls would have to be about .1" thick from the outside. Like the Miabot pro, it would have indented spaces for wheels so they would not fall outside of the chassis.
Offline pomprocker
« Reply #4 on: November 25, 2008, 03:42:12 PM »
I think bigbluesaw.com is having a thanksgiving sale on aluminum parts
Offline MaltiK
« Reply #5 on: November 25, 2008, 05:45:01 PM »
Try BBS as mentioned or Polou
Warranty
Offline Gertlex
  • Helpful? 23
« Reply #6 on: November 25, 2008, 10:48:12 PM »
That's only on plate aluminum though.
My suggestion is to get a piece of plate aluminum cut, and then do the bending into the desired shape.  MUCH cheaper.
I
Offline ArcMan
  • Mmmm... Plasma
« Reply #7 on: November 26, 2008, 08:44:31 AM »
If you can tolerate some variation in the dimensions, Bud Industries, Inc. makes some very nice cast aluminum boxes with screw-on tops.  For example, Model # AN-1310 is 4.00" x 4.75" x 4.75" with 0.130" thick walls.  Price is $34 at Newark Electronics.  There are many other sizes to choose from.
Last post January 17, 2008, 04:07:00 PM
by BANE
Last post May 24, 2009, 04:28:30 AM
Last post June 07, 2009, 08:45:50 AM
by BANE
Last post December 25, 2010, 11:19:12 PM
by waltr
