Author Topic: How do the grippers in this robotic gripper open and close?  (Read 2389 times)
Re: How do the grippers in this robotic gripper open and close?
« Reply #1 on: November 25, 2008, 06:21:21 PM »
its missing a part
theres a motor with a gear thats in between the two gears that turns them
Offline szhang
« Reply #2 on: November 25, 2008, 06:42:46 PM »
I don't think it is missing a gear.
One of the two gears has to be actuated though (there needs to be a motor turning one of the big gears), in google sketchyphysics you can drag on the gear and turn it.
« Last Edit: November 25, 2008, 06:43:38 PM by szhang »
« Reply #3 on: November 25, 2008, 07:40:44 PM »
well yea you can do that also , or add another gear to it , both would yield the same result  - as long as each fingers gripper is turning in the opposite direction you are fine.
Offline AdvsNoob
  • Younge Inventer
« Reply #4 on: November 26, 2008, 11:00:20 PM »
I be leave you need a servo ^_^ never really made gripper, you might need two but there really not alot of money
Offline MaltiKTopic starter
« Reply #5 on: November 27, 2008, 05:35:42 AM »
Do I need PWM motors to do the trick? I ask this because it seems I can just use a transistor to switch the direction of the motor if no Motor Chip is used. If I just used a regular DC motor underneath the gripper mechanism, connected to one gear? What I am asking is, is there an alternative to using a servo instead of using a motor with a motor driver chip?
Warranty
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #6 on: November 27, 2008, 06:51:31 AM »
The purpose of using a servo is that the servo can go to many positions while a DC motor (with driver) will go from full open to full close. However, if you attach a geared DC motor on one wheel and attach a potentiometer to the other wheel (and plug it in an analog pin of your microcontroller), you can move the motor until the pot reaches a certain position then put the motor on brakes (send same signal on both direction lines, like shorting the motor leads) to hold that position. This way you will simulate a servo.
Last post August 30, 2007, 04:59:07 PM
by airman00
Last post December 01, 2009, 03:13:43 PM
by borg
Last post September 06, 2010, 12:47:56 PM
by Kelpy
Last post December 02, 2010, 09:44:52 AM
