Author Topic: Problem to activate DC motor  (Read 2474 times)
Offline roi_tauTopic starter
« on: November 27, 2008, 08:55:32 AM »
Hi Guys.
My Robot should activate little vibration motor.
The schema is attached
My battery is 3.6 volt (3 cells) Ni-MH
The base is connected strait to the uC with no resistor (It doesn't work with R>0.5K)
What do you think?
Is my values correct?
The circuit works but I want it to be correct.
Roi
Offline jamort
Re: Problem to activate DC motor
« Reply #1 on: November 27, 2008, 09:02:15 AM »
you might want to make sure the motor works.... plug a battery into it with out it in the circuit.....
I think you said basically doesn't work from the get go because if it stopped working it could of been to much voltage
« Reply #2 on: November 27, 2008, 09:07:23 AM »
The motor works with and without the circuit
I just want to know if the way I connected it is right,(Wont damage the transistor in the long run)
Roi
Offline ArcMan
  • Mmmm... Plasma
« Reply #3 on: November 27, 2008, 10:22:07 AM »
That circuit is fine for such a small motor.  BTW, don't use the 30 ohm resistor unless you intend to measure the motor current.  That's what it's for.
Offline szhang
« Reply #4 on: November 27, 2008, 12:30:07 PM »
make sure your transistor isn't flipped or something.
Offline ArcMan
  • Mmmm... Plasma
« Reply #5 on: November 27, 2008, 08:22:11 PM »
Ooh.  I just read your OP more thoroughly.  You must have a resistor between the uC and transistor base or you'll kill your transistor.  Take out that 30 ohm resistor on the emitter and use about a 500 ohm resistor on your base.  That arrangement will switch about 100 mA if the transistor hfe is 50 (which is typical for a bipolar switcher like a 2N2222).
« Reply #6 on: December 01, 2008, 03:18:52 AM »
The proper way would be to use a MOSFET and no resistor ;D
« Reply #7 on: December 01, 2008, 04:14:20 AM »
You mean like the 2N7000?
« Reply #8 on: December 03, 2008, 06:50:57 AM »
yes, and any PWM optimized MOSFET ;D
« Reply #9 on: December 03, 2008, 08:56:18 AM »
Hi Admin
I didnt understand your answer.
Roi
« Reply #10 on: December 04, 2008, 10:18:29 PM »
yes, just like the 2N7000.
Also, just like any MOSFET that is PWM optimized.
« Reply #11 on: December 05, 2008, 04:11:04 AM »
I didnt understand the part of the PWM optimized.
What do you mean by that?
Roi
« Reply #12 on: December 05, 2008, 10:19:04 AM »
Optimized for PWM:
http://www.societyofrobots.com/member_tutorials/node/228
To operate a DC motor, you need to PWM your MOSFET. A PWM optimized MOSFET will give you a higher efficiency. You'll see 'PWM Optimized' typically on the very first page of the MOSFET datasheet.
And remember to google before asking questions :P
