Author Topic: CNC issue: removing lines with buffer?  (Read 4019 times)
Offline AdminTopic starter
« on: February 16, 2007, 02:09:19 PM »
Im having an issue with facing acrylic on my high precision CNC.
The issue is that no matter how many facing passes I complete, there are these lines appearing in the plastic (see picture). Anyone who has ever done part facing with a CNC or a mill has probably seen these lines at some point . . .
The lines (ridges?) are so small that you cant actually feel them (feels like a perfectly smooth surface, despite how it looks).
Originally I figured they were just optical distortions because of some kind of localized thermal heating that reorganizes molecules . . . but apparently it isnt.
Normally these lines fit very much within acceptable tolerances for people, but not today . . . This facing is used for a mold for a transparent polymer (similar to as seen in picture) that cures within the mold. Strangely, when I take out the polymer after it has solidified, the lines appear in the polymer too! This is bad because I need the transparent polymer to be an exact thickness with no optical distortions for high tolerance testing.
How do I get rid of these lines?!? I have heard of some kind of buffer tool that I can use for my CNC. Anyone know about this?
Offline JonHylands
Re: CNC issue: removing lines with buffer?
« Reply #1 on: February 16, 2007, 03:07:11 PM »
Picture?
- Jon
« Reply #2 on: February 16, 2007, 03:26:44 PM »
Picture?
ummm but the picture is attached . . . :P
Offline JonHylands
« Reply #3 on: February 16, 2007, 07:33:53 PM »
Not that I can see...
- Jon
« Reply #4 on: February 16, 2007, 07:39:07 PM »
Offline JonHylands
« Reply #5 on: February 16, 2007, 09:52:32 PM »
"An Error Has Occurred!
It seems that you are not allowed to download or view attachments on this board."
I guess I'm not special enough to rate attachment privledges... ;-)
- Jon
« Reply #6 on: February 16, 2007, 11:56:44 PM »
hmmm it appears the permissions werent set entirely right . . . can you see it now?
Offline JonHylands
« Reply #7 on: February 17, 2007, 06:34:22 AM »
Yes, I can see it now :-)
You are using an endmill, right?
I typically take out the lines like that on a flat surface with a file, but I wouldn't expect that to work here.
Some jeweler's rouge might do the job, with a rag and a smooth block. You're basically trying to polish the surface. Look into stuff you use to polish a car - a buffing pad on a drill with some polish might do something as well.
- Jon
