Author Topic: Dumb question on 5V versus 3.3 Volt devices and AXON  (Read 1983 times)
Offline DscrimagerTopic starter
« on: December 06, 2008, 12:03:34 PM »
I want to interface an ADXL330 triple axis accelerometer to my AXON for my 'bot.
Now my question is, as long as I power this board from the 3.3V source on the AXON I can still sample the accelerometer ouput pins with the regular AXON ADC pins correct? I would just see values that are from 0 - 3.3 Volts versus going up to 5 volts?
I did a little searching but didn't find anything about this....
Doug
Re: Dumb question on 5V versus 3.3 Volt devices and AXON
« Reply #1 on: December 06, 2008, 01:47:13 PM »
I just found the answer in the header files... basically what I thought was true...power from 3.3 header and read from normal ADC pin,...
Doug
Offline pomprocker
« Reply #2 on: December 07, 2008, 01:53:29 AM »
I don't think you can use 3.3v to power the Axon when it is running at 16MHz
« Reply #3 on: December 07, 2008, 03:25:46 AM »
Dscrimager, yeap you are correct.
pomprocker, he means the 3.3V output on the Axon ;D
This device also uses the ADXL330, just in case you wanted something off the shelf:
http://www.dimensionengineering.com/DE-ACCM3D.htm
Last post July 06, 2008, 10:49:15 AM
by twintriode
Last post October 07, 2008, 06:18:31 AM
Last post September 10, 2009, 06:12:39 AM
by SmAsH
Last post August 20, 2010, 03:10:40 AM
by Kelpy
