Author Topic: Looking for SN74HCT138N with non-inverted outputs  (Read 842 times)
Offline CommanderbobTopic starter
  • Embeddedmicro.com
« on: December 07, 2008, 10:06:21 PM »
OK, I made a mistake. I designed a PCB to use the SN74HCT138N demultiplexer. The problem is for some reason I did not realize the output was inverted and now it is causing problems. I need to find one with the same pinout that does not have inverted outputs, ie only one pin is high at a time.
I have looked all over and I can't find any that have non-inverted outputs, let alone the same pinout.
Thanks for the help,
Justin
  • Embeddedmicro.com
Re: Looking for SN74HCT138N with non-inverted outputs
« Reply #1 on: December 07, 2008, 10:08:48 PM »
Wow, right after I posted this I came across one,   M74HC238B1R.
Last post October 27, 2009, 04:46:56 PM
by Webbot
Last post October 25, 2011, 05:43:05 PM
by waltr
Last post May 11, 2012, 08:49:52 AM
by Fionnuala
Last post April 09, 2013, 03:27:48 PM
by idee17
