Electronics > Electronics
2D Mapping Suggested Beacons?
(1/3) > >>
I've been tasked as part of a current project to create 2D mapping for a Autonomous Vehicle which has the capability of Object Recognition with use a rotating camera.
 We currently are able to isolate and recognise information such as a right and left turn from a sign what we need is to be able to map the positions of these signs in a 2D grid and come up with a way of avoiding obstacles in the way.
The obvious problem that arises from this is how to work out the position of the car in relation to this map when it moves. I literally have no more Input/Output pins left apart from some PWM pins and luckily still have a full selection of ADC pins available. (Currently using DSP chip F2812 EzDSP starter kit).
i could place 4 beacons in the corner of the room i wish to map but as i require constant information as to the position of these beacons in relation to the car to accurately note where the car is within the 2D map.
Any suggestions as to what can be used as beacons and what sensors would be required to keep track of the position of the beacons in relation to the vehicle?
Ok so what you ask for is a little complicated, but there are many ways to go about this.
First, a few questions.
What precision do you need? You robot will always have error - its just a question of how much is acceptable. More error allowed, the easier it is to program the robot.
How big is the playing field? Beacons suck at far distances . . . :P
Have you considered using encoders? Yeap, analog pins can read digital signals . . .
What about using Sharp IR to gauge distance from an object? That tutorial will explain how I generated a 2D map using just a sharp IR.
If your camera uses signs in the path, then by knowing the size of the sign a-priori your robot can calculate it's exact position with relation to that sign. Its sorta like stereo vision, except you only need one camera since you know the pixel to size ratio beforehand. Since you already have the camera working, this is the method I would recommend.
If you choose to use beacons, a very easy way is to make three beacons out of a bunch of LEDs: blue, green, and red. Then you put a simple analog color sensor on your robot to tell which beacon you are looking at. But it may not work depending on the position accuracy you require . . .
hi Ratfink,
so you are working on a project somewhat similar to my own.
so i decided early on, after doing a load of reading on stereo vision and pattern recognition that there are less processor intensive ways of sensing a robot's environment with a camera.
if you decide to go for beacons i have had some success making beacons for computer vision projects.
i made my beacons from LEDs (the brighter the better). you want to make the LEDs flash at a known rate.
you then want to take 2 pictures from your camera, timed so that exactly half a beacon cycle has passed.
this way you will get 2 pictures which are identical except in one the beacon will be lit. in the other the beacon will be dark.
subtract one image from the other and you will be left with only the beacon in the diff of the 2 pictures.
i had a working prototype for my latest bot. the beacon will be on it's battery charger. (i say "had". it's currently dismantled and will not be put into use until my bot becomes a little more complete.)
there are actually 2 LEDs, a known distance appart and a known height above the ground.
once i have created a diff of the 2 pictures i apply some maths to find the center of the 2 blobs of colour to get 2 points on the screen.
i can then apply some more maths to work out how far away each LED is using the height it appears at in the picture. (as the LEDs are mounted 1 meter higher than the camera, far away LEDs will appear low down in the picture. near LEDs will appear high up.)
now my bot knows how far away each of the 2 LEDs are, it can work out not only how far away the battery charger is and which direction relative to the bot, but also what direction the bot is approaching the charger from.
localisation from a single beacon.
neat hu?
I will attempt to use the Sharp Distance sensor 40cm - 300 cm to build a 2D map using the technique you described in combination with the encoder.
The distances im working with is basically a large room the robot is a small radio controlled type robot
Heres some pictures by the team that built it last year we've basically inherited it and been asked to come up with a new idea and we've decided to build a autonomous navigation robot which will use a rotating camera for object recognition. It will basically consist of a few large signs pointing right and left directions with some obstacles placed randomly around the room and attempt to simulate obstacle avoidance and recognition by doing turns based on the signs it sees.
As for size of room as i said its a large room i've not got exact dimensions but 30m square if not bigger the size of the signs are also going to be quite huge about 50cm squared to help with our object recognition.
What im planning to do is build a 2D map with positions of these signs create some sort of navigation algorithm that approaches the signs interprets the direction its pointing while avoiding obstacles. So the accuracy is not going to have to be great it just needs to show that it can approach the rough position of the sign and make a turn to the direction its pointing whilst avoiding obstacles along the way.
The problem i can see with the encoder is the accumulated error of the position of the car hence the beacons im not sure if the colour ones can be used to give an accuracy of say 10-20 cm for the size of the obstacle course im trying to plan. The kind of thing im thinking of using is ultrasonic sensors for each beacon which will emit at certain frequencies and having a reciever on the car which will be able to track its position within the beacon. I can forsee however alot of interference problems with this type of combination.
So im looking for a beacon which will emit something constantly and the car can sense the distance between the beacons and itself and work out its rough location while its moving.
The LED idea i have already thought of and could easily implemented the only problem i forsee is that the camera would have to be able to see the LED beacons constantly to be able to track its relative position to the beacons.
Im looking for a way of tracking the cars position with beacons without having to point something in the direction of beacons.
Any ideas for beacons/sensor combination would be gladly appreciated.
Can you use color shapes or color combinations for your markers ?
You probably already have some color blob processing algorithms available, and you could use the combination of different colors or color + shape to create your landmarks.  You'll need to experiment with color segmentation routines in various lighting conditions, but it sounds like you are operating in a controlled environment, so this should be manageable.
If you had some additional digital inputs, I'd suggest using an array of 4 IR detectors such as Vishay TSOP 1738 to get 360-degree coverage (1 bit per beacon).  Each detector has a 180-degree field of view, so the overlap of fields will give you some directional sense.  The TSAL 6200 IR emitters have quite a good range (10-20 meters), and you could modulate the different emitters with a different bit pattern in order to discriminate between beacons.
[#] Next page
