Author Topic: motor driver (syren 10)  (Read 1334 times)
Offline karmaxTopic starter
« on: December 11, 2008, 09:43:41 AM »
hi ,guys i am working on syren 10A motor drivter that i brought from  (http://www.dimensionengineering.com/SyRen10.htm) dimension engineering .i can able to drive only one motor from 1 motor driver. if i want to drive multiple motor then i have to give first address then command then speed but its nt working .... can anybody help me regarding this.....
Re: motor driver (syren 10)
« Reply #1 on: December 15, 2008, 04:45:02 AM »
Define 'but its nt working' meaning what errors did you get, why you think it isn't working, what voltages its getting, how you are controlling it, relevant source code, etc.
We know nothing about your setup ;D
« Reply #2 on: December 22, 2008, 08:25:48 AM »
actually when i tried nothing will show ..
i have tried in matlab and labview
matlab code is given below:
s = serial('COM3');
fopen(s);
for n = 1:100
fwrite(s,10101010,'uchar');
pause(.1);
fwrite(s,10000010,'uchar');
fwrite(s,01000000,'uchar');
fwrite(s,00000000,'uchar');
fwrite(s,01000010,'uchar');
end
fclose(s);
« Reply #3 on: December 23, 2008, 01:03:55 AM »
can you give me any code that can send 170 value then delay then send 130 then 0 then 64 then 66 means it should be a packet .... please help me...
« Reply #4 on: January 09, 2009, 07:21:27 AM »
ok so wait . . . its connected to your PC? can you further explain your setup?
I suspect you simply got the baud rate wrong or you're applying an incorrect voltage. Did you check for those?
Last post March 31, 2007, 07:07:03 PM
by sdk32285
Last post July 04, 2008, 09:29:48 AM
by Steve Joblin
Last post September 25, 2008, 05:48:02 PM
by Ro-Bot-X
Last post October 06, 2008, 04:24:36 PM
by javafiend
