Author Topic: Arduino Duemilanove, code question, pause or stop function  (Read 9097 times)
Offline TreetpflyerTopic starter
« on: December 14, 2008, 03:06:19 PM »
Hi all,
I've been working with the Arduino code.  It seems different than just normal C.  I have a normal hobby servo setup and it's working well.  I would like to insert a switch in the loop code that will allow me to start and stop the loop(on and off).  In the past I've used a goto end statment, but that was years ago and I'm still learning to write code.  When I try to compile it, it gives me an error of "error: 'end' was not declared in this scope"  This is just a copy paste of the servo code from Ardiuno website with some changes for the switch.
Is there something better I can use?  Thanks for your help.
The code is as follows:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int potpin = 0;        // analog pin used to connect the potentiometer
int val;                   // variable to read the value from the analog pin
int switchPin = 2;    // start stop switch
int val2 = 0;           // variable to read the value from the start/stop pin
void setup()
  myservo.attach(9);                // attaches the servo on pin 9 to the servo object
  pinMode(switchPin, INPUT);    // declare switch as input
void loop(){
  val2 = digitalRead(switchPin);        // read input value of switch
  if (val2 == HIGH) {                      // check the switch position
  val = analogRead(potpin);             // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                      // sets the servo position according to the scaled value
  delay(0  ); }                               // waits for the servo to get there
  if (val2 == LOW); {                   // check the switch position
   goto end;                            // skips over the servo code and goes to end, then repeats
end;
Offline Dscrimager
Re: Arduino Duemilanove, code question, pause or stop function
« Reply #1 on: December 18, 2008, 11:50:16 PM »
Well, you need to declare a label called "end". You have a semicolon ";" after the word end" where it looks like you want the label to be and it needs a colon ":".
Change ->
end;
to
end:
where you want the label, but NOT on the goto. Can you see the difference? Sometimes it's hard for us to see, but not to the compiler.
Doug
Offline Kirk
« Reply #2 on: December 21, 2008, 09:56:59 PM »
Greetings,
In general using goto in C is a bad idea.
Rather than stopping the loop, keep looping but just let it do nothing.
If I understand your goal as being do not execute the servo code when the switch value is LOW. Then all you need to do is eliminate the second if statement.
Sincerely
Kirk
Last post April 13, 2009, 12:33:53 PM
by Ro-Bot-X
Last post July 09, 2009, 03:52:51 PM
by SmAsH
Last post November 08, 2009, 10:17:16 PM
by awally88
Last post February 02, 2013, 01:12:25 PM
by jkerns
