Author Topic: stepper motor + beam sensor  (Read 1077 times)
Offline dsesmgTopic starter
« on: December 15, 2008, 12:39:47 AM »
Hi, I used arduino before to control a stepper motor by using ULN2003 circuit(http://electronics-diy.com/electronics/stepper_motors.php) as the driver of my stepper motor.
I am trying to build a small conveyor (Length : 300mm x Width : 130mm), which rotates for a designated distance(for about 100mm) every time a beam sensor is disturbed.
So, I figured that this kind of simple process can be done by other controllers that are way cheaper than arduino.
My question is (1) what type of software and chip should I use for my application?
(2) In order to use a beam sensor with this stepper motor driver circuit(http://electronics-diy.com/electronics/stepper_motors.php), how should I connect the sensor to this circuit(or to controller circuit)?
My stepper motor has a specification like this.
*Voltage    *Current    *Resistance   *Inductance   *Holding torque
 4.0V          0.95A         4.2Ohm          3.3mH          1.6kgf.cm
Any word of advice from you would be very helpful to me.
Thank you.
Re: stepper motor + beam sensor
« Reply #1 on: December 27, 2008, 03:23:27 AM »
You can't get much cheaper than an Arduino . . .
Try this:
http://www.societyofrobots.com/step_by_step_robot.shtml
and this:
http://www.societyofrobots.com/robot_50_robot_sharpIR.shtml
Last post September 05, 2007, 07:12:24 AM
Last post September 15, 2008, 03:59:10 PM
Last post September 30, 2009, 04:48:57 PM
Last post July 20, 2010, 06:56:03 AM
