Author Topic: my uC doesnt work with 3.6 volt battery  (Read 1159 times)
Offline roi_tauTopic starter
« on: December 16, 2008, 01:07:10 PM »
Hi guys
In one circuit I'm using PIC16F886. In the datasheet they say operation voltage is 2-5.5 volt,
However,If I connect the board to a 3.6 volt supply (I'm using power supply),nothing work
Only after I increase the voltage to 4 or 4.3 volt,the circuit works fine.
Does anyone knows what can be the problem ? I tried it with the PIC16F84A and it worked fine with 3.6 volt
Thank in advance
Roi
Offline izua
Re: my uC doesnt work with 3.6 volt battery
« Reply #1 on: December 16, 2008, 03:41:15 PM »
lower voltage = lower speed. check your clock/crystal.
Offline HDL_CinC_Dragon
« Reply #2 on: December 16, 2008, 09:01:52 PM »
Are you running anything else in the circuit other than the uC at the same time?
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #3 on: December 17, 2008, 02:21:11 AM »
First of all thank you for the reply,
Im not running anything beside the uC.
The crystal may be the problem. Im using internal osiclator that I defined to be 4Mhz
Maybe I reduce it to 1Mhz or 32Khz,
What do you say?
Roi
Offline izua
« Reply #4 on: December 17, 2008, 06:35:51 AM »
I tried to change the clock but it changes the time in the circuit.
8Mhz=> 1Mhz  ==>>  delay (8 sec) => delay(1 sec)
The uC must work with 3.6V and without external osc.
Can you help me?
Please do not send me pm, unless you have to discuss personal matters.
The mcu only know to delay in oscillations. So 1 sec is converted into a number of oscillations to be wasted.
If you lower the clock, the same number of oscillations occurs in a longer time range.
You need to recompile your code with the new cpu speed.
Last post January 30, 2008, 10:47:40 AM
Last post September 19, 2008, 10:34:58 PM
Last post July 12, 2011, 01:44:38 AM
by Mato17
Last post May 03, 2013, 05:45:17 PM
by paulstreats
