Author Topic: Locking a bolt in place  (Read 3006 times)
Offline darkloafTopic starter
« on: December 17, 2008, 06:26:57 AM »
Hey,
Ive got a couple bolts i need to lock down (they unthread them selves when my motors running).
I once saw a product called bolt glue, but can't find it again. Ive also seen various washers and lock bolts that appear to be what i want.
Anyone have any recommendations?
Cheer!
Nick Deboar
Offline Rebelgium
Re: Locking a bolt in place
« Reply #1 on: December 17, 2008, 07:39:32 AM »
uhh... use double bolts...
orgcrime.net
Offline waymental
« Reply #2 on: December 17, 2008, 08:32:57 AM »
double nuts or lock-tite
Offline Gertlex
  • Helpful? 24
« Reply #3 on: December 17, 2008, 09:03:27 AM »
Lock-tite is the brand-name "thread glue" that you're looking for.
I recommend nylon lock-nuts.  Basically they're nuts.  With a ring of nylon in them that the threads cut into when the nut is put on.  The nylon provides enough resistance that it stops the nuts from coming off by themselves... Search "nylon insert locknut" at mcmaster.com
I
« Reply #4 on: December 17, 2008, 09:43:38 AM »
Great, just what i needed.
Nick D
Offline want2learn
« Reply #5 on: December 17, 2008, 01:21:48 PM »
If you use a thread locking compound (loctite), be sure to use it sparingly as nuts can be bloody hard to remove if you apply too much
Am I, or the others crazy?
Offline silo_xtreme
  • I really love robots, they keep me awake at night.
« Reply #6 on: December 17, 2008, 01:45:54 PM »
What about self locking washers?
Offline Rebelgium
« Reply #7 on: December 17, 2008, 04:54:10 PM »
They'd work too, but with some vibration and time they'll loosen...
orgcrime.net
Offline HDL_CinC_Dragon
« Reply #8 on: December 17, 2008, 04:57:44 PM »
Dont suppose using set screws is an option?
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Offline Gertlex
  • Helpful? 24
« Reply #9 on: December 18, 2008, 04:59:29 PM »
Why would you set screw a bolt? o_O
Nylon lined nuts > self locking ones any day... except where weight's concerned. And that's miniscule.
I
« Reply #10 on: December 20, 2008, 10:15:33 AM »
Being a tight-ass (Australian for one who doesn't spend much money), ive fashioned some out out of hdpe. I just cut some squares, drilled a hole 1mm smaller than the intended thread, and fits like glove.
Nick
Offline Gertlex
  • Helpful? 24
« Reply #11 on: December 22, 2008, 09:38:40 AM »
Nick
Good solution :)
Plastics and rubbers always make nice vibration-resistant fastners.  Not as strong, but strength is rarely needed in small robots.  I've used pieces of rubber hose in a similar way, myself.
I
