Author Topic: $50 Robot - EZ High Voltage Fuse Reset Device  (Read 1545 times)
« on: December 19, 2008, 01:52:55 AM »
Tutorial in the works!
This easy to make breadboard adapter device will factory reset the fuses on your ATmega8/168 if you've ever accidentally disabled reset, isp, or your internal oscillator, etc..
http://www.societyofrobots.com/member_tutorials/node/239
I've attached a little teaser photo
« Last Edit: December 19, 2008, 01:59:11 AM by pomprocker »
Offline Trumpkin
Re: $50 Robot - EZ High Voltage Fuse Reset Device
« Reply #1 on: December 19, 2008, 09:15:30 AM »
This sounds pretty awesome! Can't wait to see the final tutorial.
Robots are awesome!
Offline Karlooie
« Reply #2 on: September 06, 2010, 02:31:41 PM »
Hi, I accidentally programmed the reset disable fuse, so now my atmega88 is bricked.
I did write on a second atmega88 the hex file HVFuse8.hex (i didn't re-compliled it because i don't have the arduino s/w).
I did put the 1kohm resistor R1 R2 R3 (on the transistor and led) that as i could imagine are more important, but for the moment i didn't put the 1k resistor on the lines because at the moment i dont have enough...
The led is switched on but doesnt switch off when i push the button, and the target is still bricked :(
i did double checked the connection and everything seems correct.
i did connected +5v to vcc and a second try also to avcc (good atmega88)
Any idea? could be because of the missing resistors? I will add them as soon as i get a chance.... but to me it seem strange that the led doesn't turn off at all...
i left the fuses on the good atmega88 set to the default values, correct?
thank you for any reply...
carlo
Last post January 14, 2008, 02:09:57 PM
by rox2007
Last post May 02, 2009, 04:23:17 AM
by billhowl
Last post July 28, 2009, 08:02:56 AM
by awally88
Last post December 22, 2009, 01:39:07 PM
by ed1380
