Author Topic: Mounting servos  (Read 1833 times)
Offline mihiesTopic starter
Mounting servos
« on: December 21, 2008, 02:03:30 PM »
How do you mount servos? Do you buy mounting brackets or make them yourself?
Re: Mounting servos
« Reply #1 on: December 21, 2008, 07:00:12 PM »
Double sided foam tape works great. But for more professional looking robots I sometimes use mounts from budgetrobotics.com
Offline Trumpkin
Re: Mounting servos
« Reply #2 on: December 23, 2008, 08:45:33 AM »
Zipties work well too.
Robots are awesome!
Offline kd5kfl
Re: Mounting servos
« Reply #3 on: December 23, 2008, 09:13:31 AM »
Plexiglass. it helps that I have access to a milling machine. Drills and taps easy, looks great.
Offline frodo
  • BOW DOWN TO MY MIGHTY STARE!!
Re: Mounting servos
« Reply #4 on: January 06, 2009, 12:06:38 PM »
Use velcro or for a more permanent mount, screw them in to the material you're using.
OMG!!!! I AM SUPREME ROBOT!!!
Check out my Web
Offline pomprocker
Re: Mounting servos
« Reply #5 on: January 06, 2009, 05:22:40 PM »
I buy mounting brackets, my time is worth more than the time it would take to make them, plus I'd rather have a more professional looking robot.
Re: Mounting servos
« Reply #6 on: January 06, 2009, 05:31:59 PM »
I'm starting to think of using Sintra for brackets - as well as all my other robot parts .
I'll buy some Sintra in the next month or so and test it out
http://www.solarbotics.net/starting/200207_sintra/200207_sintra.html
To bend a piece of Sintra®, you just boil it in water for 10 - 15 seconds (the length of boil determining how soft the material gets). After boiling, remove the piece with tongs (gently, so as not to leave an imprint of the tong in the piece), quickly bend it to your desired shape, and freeze it in shape with cold water. If you mess up, it's no problem -- keep your water boiling, and you can just repeat the process.
I assume that I can use molds as well.
Offline paulstreats
  • Helpful? 20
Re: Mounting servos
« Reply #7 on: January 06, 2009, 05:44:06 PM »
My favourite solution is L shaped aluminium brackets. They are made to go on corners of kitchen units and stuff. Basically I just drill holes to match the servos on one edge and the same holes on the other then cut the pieces off.
I meant to do a tutorial on it but after cutting 36 servo brackets I havent needed any more doing just yet. As soon as I do I'll video the process. - this was when i realised how easy using alumium is, and its superb strength to weight ratio
Things like this can be really easy to do, its just a case of finding the right material and using a bit of imagination.
Last post June 03, 2009, 09:35:52 AM
by galannthegreat
Last post April 02, 2010, 07:12:34 AM
Last post September 16, 2010, 03:02:12 AM
by Alfa_Zulu
Last post August 20, 2011, 05:41:13 AM
by Mad MIR
