Author Topic: underwater project  (Read 5490 times)
Offline rack2020Topic starter
Re: underwater project
« Reply #30 on: April 02, 2009, 07:39:03 AM »
sorry for posting for previous reply... because i myself found out about Sharp sensors... now one new query... shall i use RPR220 sensor for avoiding obstacle underwater?
« Reply #31 on: April 02, 2009, 07:52:08 AM »
sorry for the last reply... i myself found about sharp sensors... now my query is can i use RPR 220 sensor underwater?
« Reply #32 on: May 07, 2009, 06:06:49 PM »
Its specifically called 'Sharp IR Rangefinder'. Just google it up.
« Reply #33 on: October 20, 2009, 08:23:18 AM »
Hi people! Im very sorry that I almost forgot to post here what I did in the end! I finished my project some 4 months back. If you had followed all the posts you would be knowing that I had mentioned that I used a kinda propeller. Actually that idea got failed completely. Any underwater robot developers, dont use propeller because it just shifts the balance and the robot just sinks. If you are taking much care about the body's stability, which is the toughest part, then you can use propeller.
Ok here is what I did - This is my new own simple idea and with this I developed another small robot, smaller than the previous. It works like this:
* I had two 12V DC submersible suction motors, say A and B.
* I buit a small tank inside the robot.
* A is connected between outside pool and the inside tank of robot.
* B is connected between inside tank of robot and the outside pool.
* Actually the robot is positively buoyant, so it floats when there is no operation.
* Using A I sucked in the outside water into the tank, so the robot got sunk.
* Now I switched off A and switched on B to pump the water out of the tank, so the robot moved up to float on surface.
* I repeated this operation continously in pulses to make the robot oscillate about a point under water.
* when the 4 paddles(old idea) are rotated, any kind of motion can be achieved in sawtooth trajectory.
* Actually I had less time to make completely successful, yet I got 198 marks out 200.
Thank you all for the posts.
« Reply #34 on: October 20, 2009, 08:47:00 AM »
pics and videos, please :P
« Reply #35 on: October 26, 2009, 11:38:51 AM »
please follow this link that will summarise everything.. In the last few slides I have attached pics...
http://docs.google.com/present/edit?id=0AS8zfxvcSjJJZDRjeHJoNl8wY2M2N2JzY3A&hl=en
Last post February 25, 2006, 08:59:28 AM
Last post January 27, 2009, 08:59:16 AM
by blacksheep
Last post April 03, 2010, 11:04:31 PM
by coldwaterak
Last post June 10, 2010, 06:11:46 PM
by madsci1016
