Author Topic: AVRISPmkII connection failed problem on $50 robot  (Read 2175 times)
Offline ArmouralisTopic starter
« on: December 26, 2008, 04:00:00 PM »
hi i went through the $50 robot tutorial and i am stuck at the programming part.
I am using the AVRISPmkII programmer, and I am having a problem connecting to the circuit.  I am using an ATmega168 IC in the circuit and as i am using a breadboard, i checked more than 20 times that all the connections are correct, including the ones that connect to the micro controller..
I went through the programming steps, and when i pluged in the circuit to the programmer, BOTH the green LED's are on.  When i try to connect to the circuit (tools>avrprogrammer>conect... or autoconnect), the window pops up after a few seconds saying, "connection failed."
What could be the problem?  Both LED's are on, is it because i didnt follow the programming steps correctly, or the chip/ programmer has blow because of a short circuit?
Any Help is appriciated...  Thx in advance :(
Offline HDL_CinC_Dragon
Re: AVRISPmkII connection failed problem on $50 robot
« Reply #1 on: December 26, 2008, 04:32:29 PM »
United States Marine Corps
Infantry
Returns to society: 2014JAN11
« Reply #2 on: December 26, 2008, 08:13:33 PM »
thx, but i figured it out...
my avr studio had some glitch or something.  It stayed in updating mode or something, so once i got the updated version, ir works!!!!
i love the feeling when you work hard on something, then it finally works !!! =]
« Reply #3 on: December 27, 2008, 12:23:26 AM »
Too true my friend, too true.
Im glad it worked out for you :)
Infantry
Offline peekay
« Reply #4 on: February 02, 2009, 09:37:55 AM »
I am having the same problem. Both green LEDs are lit but AVR Studio reports "connection failed". I have tried all 4 USB ports but it is the same. How exactly was this problem solved?
Offline householdutensils
« Reply #5 on: February 02, 2009, 12:12:50 PM »
I had that same issue, It was resolved by downloading the newest version of AVR Studio and updating the firmware of my AVRISP MKII programmer.
Offline peekay
« Reply #6 on: February 05, 2009, 03:24:18 PM »
Worked like a charm. Thanks a bunch. Now I am on my way to program my first Robot  :)
Last post August 31, 2008, 08:37:32 PM
by airman00
Last post January 11, 2009, 01:02:11 AM
by Webbot
Last post February 19, 2009, 08:16:12 PM
by RiffRaff
Last post June 29, 2010, 03:57:55 PM
by mdp
